1 - 15 of 15 Posts
The airbox uses a seperate chamber for ea. cylinder, would it help any to cut out an opening between the two so there would be equal pressure? Any thoughts? ::) ::) :bigthumbsup:
RLS said:
The airbox uses a separate chamber for ea. cylinder, would it help any to cut out an opening between the two so there would be equal pressure? Any thoughts? ::) ::) :bigthumbsup:
the pressure is already equal... the intakes are at the same altitude... and the cylinders are the same volume.......the tps and the ecu talk to each other....mjm
I would think you would disturb the air more by cutting between the two. Most 4-cylinder bikes get velocity stacks on the intakes to "funnel or organize " the air flowing into the carbs. Having two streams of air hitting each other might mess up things a bit. Just my guess, but hey it's your bike.
I think you hit it on the head! Good fuel injection has separate intake runners for each cylinder and many are tuned by having them equal length.
OK !! Let me slide over her in this corner where no one will see me. :redfaced: I won't be asking that again. At least now I know. :bigthumbsup:
Bob
Bob
hey it's all good... no dumb questions.. just dumb answers...you were just thinking outside the "airbox"....mjm
Well, if it was a carb, you would be putting a choke on it and cause it to run real rich. Since I know nothing about FI, I would be quessing. Do the sensors pick up that there is no air and stop the FI ? I am always ready to learn :bigthumbsup:
Hmmmm, then it does the same as a carb and loses power from running rich? I'm getting hungry watching everyone munch away on here! :p :bigthumbsup:
With the 109 the driver's entire left arm gets sucked into the cylinder -- hurts like [email protected]##*T!!!
The moral of this is I did not look close enough I guess to see that they are connected. While I had it off, it looked to me that they were seperate chambers. :eek: :read:
Thanks for taken the time to enlighten little grasshooper :doorag: :bigthumbsup:
Bob
Right on J R! You don't want to bend it, just STUFF it DOWN into the engine! :bigthumbsup:Â
1 - 15 of 15 Posts
