1 - 6 of 6 Posts
Has anyone replaced the OEM fuel pump with this one?
Pros/Cons?
Thanks in advance.
2009 / VZR1800
Pros/Cons?
Thanks in advance.
Looks like direct fit,
others I have seen here needed slight modifications,
try "Search Comunity" window above every page here..
Thanks. Let's see, it should be here tomorrow.
OK guys, I already installed this pump and it works.
Pros: Cheaper than the OEM pump
Comes with filters ( 3 of them)
Cons: It is a little bit louder than the OEM
The filter that comes with it that is the same size as the OEM has the connector 90 degrees off, so installs at a different angle than the OEM filter. Because of this, the rubber boot won't fit.
I don't know yet if the angle of this filter will affect how long can't you go with low gas compare to the OEM filter. Time will tell
I could have ordered the OEM filter but, the cost of that would be around $65 - $70 so I decided to give the filter that comes with the pump a try and see what happens.
  • Like
Reactions: thevili
Administrator
If you look on eBay, you'll find Chinese fuel filters for the M109. You get 3 for about $8, and they are a perfect match. Quality seems to be very good, too. They fit in the rubber boot fine, which is important, because without the boot, you could stall going down long hills with a less than full tank.
Thanks. I'll order them
1 - 6 of 6 Posts
