1 - 14 of 14 Posts
Can I stiil use the stock rear turn signals with the new cycle house bracket? I don't want to cut anything up if I need new lights. If anyone has pics that would be great!
I assume you mean Directline Parts?
I asked Lamont the same question a while back and the answer is yes, we can use the stock turn signals.
Haven't ordered mine yet so no pics.........
I did the plate mod two weeks ago, and I'm using the stock lights.... You have to use some washers to make them work. I think they stick out a little too far for my taste, and they shake quite a bit.. I've ordered some small bullet lights from direct line to replace them. The rear end looks so much better with this mod, no matter what lights you use. Do it!!
Cut it off, it looks way better and its very easy to do. The meanness factor from the rear goes up about 70% without that hunk of plastic. I used the led strips for the under cowl turn signals, now just need to finish the tag holder with a cobalt back tag frame with Led. Its all very easy to do, all the wiring is right there under the fender cover. All you need is a hacksaw blade and refer to the how too post Lam has up.
Blur, MN
Yes, sure can. I used the stock lights with the cycle house bracket.
Thanks for the info. Going to chop it off as soon as the parts get in and the plates. This bike gets to much attention to not have turn signals, I have to waive at enough people already. :D
M109Riders Founder
1 - 14 of 14 Posts
