Not sure if putting these pics here is the right place but here it goes. Moderators...sorry if its in the wrong place.
Here's the story, I ride occasionally with my wife and thought it'll make her more comfortable by adding a back rest so i did however instead of buying ready fitting ones...i decide to get creative to build one on my own with of course my own silly ideas.
Here are pictures to show you how I designed it and put it together.
Step 1 - Removed original seat covers, gently peeled out original cushion and started with the frame work. As you can see, part of the back rest goes thru the base of the front of the seat so cutting a little at the was necessary. Reason for this is basically for more strength on the piece once she sits on it. 3mm thick stainless steel plate which uses the screws holes of where the rear seat is being screwed down.
Step 2 - Fitted back the stock cushion and yes again cutting of the cushion was needed to get that flush finish.
I welded a support beam to give the whole back rest even more strength.
Step 3 - Finish product with new seat wraps.
Sorry if my explanation sucks...trying to keep things short and sweet.
And yes excuse the horrible pics.
