21 - 40 of 67 Posts
Dre, I think you have a volunteer to help you do this:joke: Next thing you know, a bunch of the Chi Town guys will be running 300s:bigthumbsup:
Well you don't know Dre his hands don't get dirty ::)) I'll keep running my 280 and just won't park next to Dre that way any1 won't be able to tell the difference :)
not much room there..... :D
that photo of black diamond's was my inspiration as well ... Hope all is well with him!:bigthumbsup:
here's the 300 Metz ..... had to shave down the side of the tire on the shaft side to fit ..... still rubbed and didnt roll with the air ride all the way down ...
run the avon now and with a little more time into the fender the avon goes on and rolls when air ride is all the way down ..
I'm running a metz 300mm with no problem at all .. with all the cutting needed and running a SWAPM WORKS SWINGARM .. The only thing I done was add a 16th inch washer on the drive side and then shave down the down under brake bracket where the caliper mounts to .. to alow the proper alignment ........... :bigthumbsup:....On the avon 300 is a much smaller sidewall ...........
I'm also running a swamp works swing arm and a Metz 300 with a stock widened rim and arnott air ride. Let me know if you need any advice or have questions on the install. I ran into a lot of problems with mine but have almost all the bugs worked out.
Well I just got a Metz 300 tire and I lowered my bike 2.75. No air ride. Do I need to do any of that cutting and welding? If so, whats the going price?
Did you use the washer with the spacers they supplied? I was given a long spacer to slide into hub and a short one for the caliper side but tire is still rubbing. I have a 300 metzler on 10.5" wheel.
Not sure if I ever heard of anyone using a 10.5" wheel. My Cycle House swingarm had to be notched so that my Metzeler tire would not rub. I ended up notching both sides of the arm.
I have the swamp works 2 piece and Dave from swampworks told me others have my setup and it works.
If they say it works it must.:D Maybe someone with a 10.5" wheel will speak up. I just do not know of anyone. Which side is rubbing? If you are using the supplied spacers and it is still rubbing, then you have to shim some more or you better break out the sandpaper.
21 - 40 of 67 Posts
