1 - 3 of 3 Posts
Ok people all of you who rides with 160/60 on front, 3.5" rim or 4.25'' - which one do you think is better ?? Metz says 4.25''....
Being as you're buying new rims, I'd go with the 4.25. It probably won't make much difference. But what difference there is, is going in the right direction. The 160 on the stock rim still has a slight countersteer at exteme lean angles. Widening and flattening the profile slightly on the wider rim should improve that. I believe that is the way Stavros went as he bought new wheels too.
Thanks for advice Pegasus, I was thinking the same...
I knew that I want 280 on the rear , but I had no idea that choosing the front end setup will be so much pain in the ass, and so much more demanding...
1 - 3 of 3 Posts
