1 - 8 of 8 Posts
If i go to a 280 tire on the rear how low can i go with the lowering bones 1,2 or 3 inches?
As long as your bolts are ground off underneath the rear fender you should be good. Just make sure your rear shock is set firm enough for you not to bottom out.
so u can adjust the shock?
Yes you can, jack up your 9 then remove the metal panel that covers the rear suspension and you can use a spanner wrench to dial in the rear shock. There are settings from 1-7, 7 being the most stiffly damped.
I am 2.25 lowered with a 10inch rim and a 280.....for now...but the 280, as long as the bolts are trimmed ur OK..... GOOD LUCK!
oh was wonderin if i needed 2 trim bolts gettin ready 2 throw the 10'' on her...also 2.25 drop
1 - 8 of 8 Posts
