1 - 4 of 4 Posts
Ordered Corbin bags for my 06 m109r. Also going to put a new rear tire on. Does anyone know if a 250 Metz would be a problem with interference with the bags? If not, what front size would you put with the 250 rear? :dontknow:
I dont believe you will have any problems with a 250. As for a front tire, its all about whether or not you want to run a rear tire on the front mounted backwards. I stuck with the stock size (dunny e-3s).
Jason
The Metzeler is a 260, and is narrower than the Dunlop Elite III 250 (Metzelers are notorious for this). Bags are mounted out far enough that no tire will interfere with them. Stay with the stock size front tire.
the 250 dunnie does interfeer with the bags on all older model bags. recently corbin revamped them to run with out interferance. If you get a used set I will show you how to modify the back braket so you have clearance.
1 - 4 of 4 Posts
