1 - 20 of 25 Posts
Finally finished installing the new PM torque wheels and new tires. Sorry about the rear tire pic with the glove on the license plate. I took about 10 pics with it uncovered, and they all turned out really dark. The plate is reflective and was screwing up the camera setting (who asked cameras to think, anyway?). I think it looks better with the wider tires--need some drop bones now and some more chrome covers.
dw
Thanks ! I haven't ridden it yet, but maybe this weekend. It's supposed to be 70 degrees. Sorry Northeast :mad:
That looks great! :bigthumbsup::bigthumbsup:
Did you use the DLP swingarm or modify the stock one?
I modified the stock one. I did the cutting and took it to a local fab shop to get it welded. If I had to do it again, I would either put the final drive on and an all thread as an axle, or a plate tacked across from the short side to the long side to keep the space between the two sides correct. The fit was a little tight as the heat made the long side move in and getting the brake bracket on was a chore.
You can look at the AHahahahaha thread and I have several pics.
1 - 20 of 25 Posts
