1 - 9 of 9 Posts
I've read the threads on tires. So for those who would say it has been talked about adnausium, I really have searched to look for the answer to this: If I am going to a Metz 250 rear, I want to consider a Metz 150 front. How come everybody goes to a 160 front and there doesn't seem to be consideration for a 150? :dontknow: Am I missing something?
I think it's the height. In a 150 they are a 150/70, and in a 160 it is a 160/60. The 160 is wider but shorter than the 150. I've read of folks melting the front fender from using a 150 and not modding the fender for it. For a 160 the most you have to do is loosen the fender bolts and move the fender up as far as it will go.
this is off topic as you said you wanted a metz, but as far as I could find Dunnie is the only company that makes a 150/60vr-18 front tire. used on the honda rune. fit is just fine with no adjustments.
:agree::agree::agree:
Do NOT get the 150! Too dang tall of a sidewall.
Thanks for the clarification. :bigthumbsup:
I've asked for dissatisfied customers regarding the fat front mod. I haven't heard one complaint for the 160/60 but that hasn't been the case for the Dunnie 150/60. The profile is more pointed and 1 member had a low side crash. He switched to a 160/60 and says he's happier .
The problem I see is that you never know what the 160/260 Metzeler combo feels like until you do it. The 160/60VR18 fills out the fender perfectly. The 260/40VR18 has a taller, more rounded profile which makes it corner better than the wider, flatter Dunlop 250. MAny members tried the 150/70 front tire, only to find out that it'll melt the back of the front fender or pick up a rock that scores the underside of the fender until it breaks in two. Aside from those who say you should never run a rear tire on the front, everyone who's run the 160/60 front tire has loved it so much, they'll never go back to stock, myself included.
-Josh
Imay just do that in another 12 thousand miles. I got 11 thousand out of the stocker and 5 on this one now. I am satissfied with the performance so far and it stops on a dime. will see!
I want to do the 160 Metz but I'm afraid of the rock thing. I do ocassionally end up on gravel in my area. Can't completely avoid it.
1 - 9 of 9 Posts
