1 - 5 of 5 Posts
hey. i keep poppin my 15 qmp fuse to the t-sig. circuit. i disconnected the tail lamp harness and the t-sig harness behind the headlamp but it still pops. any body have a solution? :pray:
Trace it out and find out where the short is. I have spent countless hours tracing out electrical problems. Start were you know it is good and then go to the other end. As stated above, look at things that have been changed first.
:congrats: and :welcome: to the forum also.
Agree with Ryno. You have a short someplace.
You can use an Ohm meter to find it. Check between wires in the connectors for shorts, especially if you have done any modifications to the wiring.
thanks. thats what i will do. i was just hoping someone had the same problem so i could skip all the testing. oh well guess the garage will be utilized this weekend.
1 - 5 of 5 Posts
