1 - 15 of 15 Posts
got to the track last nite (new york international raceway park busy nite 150 racers for T&T) here are the results temp was 72 at 6:30 & got cooler as the nite went on my hand held computer batt went dead so no alt huuidity or temp info. bike has lowering bones, front end straped down, air shifter w/ a regulator (140 lbs every shift) shift light set at 6300, cut down seat, jsd-3m new version, small mesh briggs & stratton filters in the stock air boxes, amsoil, 3gals. of fuel (91 sunoco) in tank at start, small windshield I weigh 270lbs. made 6 passes here they are hope this is useful info
35psi rear/left lane 6:22 pm           Â
r/t 552
60'-1.810
330'-4.936
1/8-7.615
mph-91.32
1000'-9.976
1/4-12.012
mph-110.06
34psi rear/right lane 6:35pm          Â
r/t 545
60'-1.791
330'-4.949
1/8-7.640
mph-90.97
1000'-10.005
1/4-12.046
mph-109.79
34psi rear/right lane  6:58pm          Â
r/t 505
60'-1.735
330'-4.882
1/8-7.89 (HIT REV LIMITER!!!
mph-69.59
1000'-
1/4-
mph-
34psi rear/right lane 7:17pm           Â
r/t 597
60'-1.796
330'-4.983
1/8-7.695
mph-90.26
1000'-10.080
1/4-12.133
mph-109.14
36psi rear/left lane 7:37pm           Â
r/t 497
60'-1.793
330'-4.989
1/8-7.707
mph-90.10
1000'-10.092
1/4-12.146
mph-109.09
34psi rear/left lane lane 8:05 pm           Â
r/t 483
60'-1.334 (?????? does not look right compared to the rest
1/8-7.210
mph-90.46
1000'-9.589
1/4-12.086
mph-109.58
I question this pass because of the short times thoes are drag bike short times & the end result should have been in the high 11's the other guy was just running to the 1/8 on a sled a buddy of mine also had this w/his stock v max a 1.337 & the other guy had a 1.311 looks good on time slip but no way computer glitch???
r/t 552
60'-1.810
330'-4.936
1/8-7.615
mph-91.32
1000'-9.976
1/4-12.012
mph-110.06
r/t 545
60'-1.791
330'-4.949
1/8-7.640
mph-90.97
1000'-10.005
1/4-12.046
mph-109.79
r/t 505
60'-1.735
330'-4.882
mph-69.59
1000'-
1/4-
mph-
r/t 597
60'-1.796
330'-4.983
1/8-7.695
mph-90.26
1000'-10.080
1/4-12.133
mph-109.14
r/t 497
60'-1.793
330'-4.989
1/8-7.707
mph-90.10
1000'-10.092
1/4-12.146
mph-109.09
r/t 483
1/8-7.210
mph-90.46
1000'-9.589
1/4-12.086
mph-109.58
Yes you are right,if you acutally ran the 1.3 60 footers,which means you gained 4/10 s on your old time,you now should of been in 11.8's somewhere,so there lights made a mistake,on either the short times or it did not calculate properly on the long end,either way you have been very consistant all summer,and i cant see why you would of just magicly would jump out 4/10s quicker with out doing something major to your bike other than tire pressure. But what its worth,i enjoy reading when ever any of you guys make these runs and show us all of your gains to date,it shows this bike is still preety darn quick for a big cruiser,keep up the good work.. :bigthumbsup: :doorag: :super:
I am not a drag racer so, don't fry my chicken, but why are you running only 34 psi, you ran faster with 35, have you run with 42 in the rear? Again, forgive, because if I was racing it would be "really fat guy racing", and the leathers would wieght as much as my wife.
Trying to learn.
TAZ
you may run faster top end with more tire pressure, but in Drag racing Traction is the name of the game, the race is won or lost in the first 60ft. lowering the PSI gives the tire a bigger contact patch, hence better traction. with factory rated tire psi, you wil just sit and spin at the green light. also is why a very good and smokey burnout is best for traction along with lower tire pressure.
Trying to learn.
TAZ
Those are good :bigthumbsup: :bigthumbsup: Mind me asking what size rear tire your using now? :dontknow:
Bob
stock rear tire ran 31 psi yesterday & the bike hooked even better 60' went down looks like that will be the psi for now waiting on the big air from hal to see if that improves the bike or just lose 30 lbs to put it in the 11's
1 - 15 of 15 Posts
