Suzuki's "special tool" for FI codes - free for all to enjoy. - Page 2
Page 2 of 2 FirstFirst 12
Results 31 to 58 of 58
Thread: Suzuki's "special tool" for FI codes - free for all to enjoy.
  1. #31
    Very Active Member OGPAULG's Avatar
    Mar 2014
    Cleveland Ohio
    This is good to know
    One who leads with no followers is merely taking a walk
  3. #32
    Active Member smokd's Avatar
    May 2014
    australia
    Default code reader
    hey fellows mick from down under
    wat i have done with my109 is pulled those 2 diagnostic wires from the white plug
    drilled small hole in side cover near ignition barrell put micro toggle switch there
    hooked the wires to toggle swich doesnt matter which wire goes to on /of either way will work
    that way u can ride or watever and check if u have codes
    looks great works great and u dont have to take side plate of to read codes
    hope this helps
  4. #33
    Jul 2008
    Forney, TX
    Quote Originally Posted by smokd View Post
    hope this helps
    Can you post pics of the setup?
  6. #34
    Mar 2014
    Cleveland Ohio
    definitely would like to see pics
  7. #35
    Super Moderator HyperPete's Avatar
    May 2008
    Adams County, Pennsylvania
    hope this helps
    What happens when you have a problem that Suzuki needs to diagnose and they cannot connect the Suzuki Diagnostic Tool any longer?
    It's not a bad idea, but I would probably splice new wires into the two diagnostic wires before the plug, and run THOSE to a switch so that if ever needed, the diagnostic connector can be used for it's intended purpose.
    - My memory's not as sharp as it used to be. Also, my memory's not as sharp as it used to be.
    - God grant me the senility to forget the people I never liked, the good fortune to run into the ones I do, and the vision to tell the difference.
  8. #36
    Jun 2012
    Ajax, Ontario, Canada
    Angry What a joke $40.00 from Suzuki Dealer in Newmarket, Ontario, Canada
    What a joke.
    I call a local Suzuki dealer to ask them if this tool is in stock and how much.
    They told me it was $40.00.
    I used a piece of wire worth maybe .02, worked like a dream.
    If Suzuki knows this is a problem, why haven't they replaced the part with one that lasts.
    They have the balls to try and sell a piece of wire with a booklet for $40.00.
    Here is the plug which uses the "special tool". Pull the left side cover off by the ECU, and there will be two unused plugs with black boots on them. One of the plugs inside the rubber boot is black and the other is white. Remove the boot from the white plug.
    To keep perspective, rotate the white plug so that the plug 'lock' pin is on top. See the highlight in the picture below:
    Then on the right side of the plug, you will insert your "special tool" into the top right pin connector hole and the bottom right pin connector hole.
    Turn the bike ignition on - there is no need to start the bike. The FI code will display in the odometer box. C##. Look up our FI error code in the manual, or call Suzuki with the number, and then you'll know what's up with the FI.
    Now, another tip about the FI code in the odometer box using the "special tool". When you look into the odometer box and see the code, e.g. C46 (EXCVA - exhaust control valve), just to the left of the code will be a hash mark. That represents the position of the throttle open percentage/position. If you then open up your throttle, the hash mark will move up screen to represent the increasing open position of the throttle. If it is moving appropriately, that is supposed to mean that your throttle is working ok.
    That's it. That's all I know about this. Enjoy.[/QUOTE]
  9. #37
    May 2008
    Uh, no, Steve. This was a tongue-in-cheek post (nine years ago) telling you to use a piece of wire.
  10. #38
    Active Member DonNJane's Avatar
    Jul 2008
    Okotoks Canada
    This is an excellent post and helped me immensely this past weekend when my bike had been displaying the FI code steadily for more than a week.
    The only time I've ever had this happen before was when I'd gotten bad gas and it stopped with a new tank of fuel.
    My problem this time is that my code read C-00 no fault found
    Yet the light remained on........
    Anyone else had this issue?
    Don
    08 Boulevard C109RT
    Calgary Canada
    IBA member # 38549
  11. #39
    Apr 2014
    Chesterfield, VA
    Quote Originally Posted by DonNJane View Post
    Don't shut you bike off when you are checking the code. Start it up, make sure the FI light is on, then check the code as described in this thread before shutting the bike off.
  12. #40
    Jul 2008
    Forney, TX
    Use the kill switch to turn the bike off but leave the ignition on. Then read the code.
  13. #41
    Feb 2017
    Quote Originally Posted by HyperPete View Post
    You are correct HyperPete, it was 100% young in cheek then.
    JC (JDC)
  14. #42
    Aug 2006
    Okanagan Valley B.C. Canada
    Love these old post! Good stuff!
    Sent from my iPad using Tapatalk
    Vegas Meet May 17-24, 2017! Let's bet on a great time!
    https://www.m109riders.com/forums/sho...d.php?t=321882
    Riders Meet 2018, Nakusp BC. Date ?
    Planning stage. Location secured
  15. #43
    Very Active Member THUNDER217's Avatar
    Jun 2008
    UPPER MARLBORO, MARYLAND
    Default NEWER MODELS
    One guy did ask does this still work on the newer nines. Not only using the neat Suzuki tool but also punching out wires to get rid of the F1 light. I thought I remembered somewhere that this was not so for the newer bikes can some one chime in with a newer machine. Worked fine years ago on my 08. some member have newer bikes now and are having the dreaded F1 fault. Let me know. Thanks.
  16. #44
    Very Active Member Meiklejohn's Avatar
    Feb 2011
    Sydney, NSW, AU
    Quote Originally Posted by THUNDER217 View Post
    Exhaust Fi light doesn't have the pin in the same spot. Not sure where it is but just got the exhaust servo eliminator plug in
    Sent from my E5823 using Tapatalk
    Four wheels move the body, two wheels move the soul...
  17. #45
    Jun 2008
    Default F1 PIN
    That's what I thought. Does anyone know when the PIN became was shut down to eliminate the F1 light. What years. Thanks.
  18. #46
    Jul 2008
    Forney, TX
    I have an 07 and removed my pin. I believe they changed the wire setup when Suzuki started putting the tach up in the cowl. But Im not posistive. For those, without the #7 you are really better of getting one of the plug and play units.
  19. #47
    Feb 2011
    Sydney, NSW, AU
    Correct. I think that was 2010 or 11 with the black with red stripe
  20. #48
    Feb 2011
    Sydney, NSW, AU
    Quote Originally Posted by Meiklejohn View Post
    Actually. I've had a 2009, 2010, 2011 and now a 2012. I recall removing the pin on my 10 and 11
  21. #49
    May 2017
    upstate NY
    Default code reader
    hope this helps
    send a picture of that
  22. #50
    Jan 2018
    South Africa
    Unhappy Dealer mode
    Hi Guys. I'm battling to get my 200 M109 into dealer mode. Unfortunately the images on this post don't show. Can anyone help.
  23. #51
    Jan 2018
    South Africa
    Default This is what the dealer plug looks like
    Quote Originally Posted by Olmeca121 View Post
  24. #52
    Sep 2012
    Long Island, NY
    Plug looks like this and is located behind youe left cover behind your seat lock
  25. #53
    Sep 2012
    Long Island, NY
    This will help the plug looks the same and what needs to be done is the same too.
  26. #54
    Support Team Member Board Support-2's Avatar
    Feb 2010
    Follow the instructions here: Photobucket "fix" for Chrome andChrome-based browsers (and now, Firefox!)
  27. #55
    Feb 2016
    Pensacola, FL
    Default Special Tool
    Good Day Sir,
    All of your pictures with respect to the special tool to reveal F1 codes have been removed. Could you please send me the pics via email or send me info on how to get one of these special tools.
    Your assistance would be most appreciated.
    Bill
    Quote Originally Posted by JC View Post
    Ok, Suzuki talks about a "special tool" to reveal the FI codes in the manual. The "special tool" is $15.99 from Suzuki. In reality it is a single toggle switch with two wire leads and probably a pin insert at each end.
    The "special tool" works by using the two leads to connect two jumpers on a wire header with the 109.
    I'm cheap and spoke to a local bike shop, P**** T***, and John told me all about the "special tool" when I asked him. I won't put the shop name in because I'm not sure if Suzuki police exist.
    Ok, I have a "special tool", only $15.99, see pic below:
  28. #56
    Jul 2008
    Forney, TX
    Quote Originally Posted by corkman View Post
    Good Day Sir,
    Bill
    Here is a newer post.
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Sent from my SM-T580 using Tapatalk
  29. #57
    May 2008
    Good Day Sir,
    Bill
    It's just a short piece of wire. See post numbers 52 & 53. You can also use a paper clip or a cotter pin.
  30. #58
    Hey, I have a question. I got codes c32&33 ,injector signal code, is that the brown 4 pin connector under the gas tank? I have a 2009 m109r
Tags for this Thread
