Reinstalling driveshaft to u-joint - Page 3
Page 3 of 3 FirstFirst 123
Results 61 to 75 of 75
Thread: Reinstalling driveshaft to u-joint
  1. #61
    Aug 2010
    Great NW
    Quote Originally Posted by Kazimodo View Post
    figured I had something ......guess not ,,,,,,I'll be ready to remove secondary.:berr2:
    I did it once just to see what it's all about. Took me 30 minutes to take the secondary off check everything out and put it back together. Just be careful with that big o ring when putting it back together.........
  3. #62
    Sep 2012
    Long Island, NY
    If you loosen the hub nuts to where it's just hanging on, get a couple of towels, one on each side you can work it in. I've done it this way before without removing the hub. I'm also one of the lucky ones that stabbed it and it went right in, happen to me twice once in one of my video when I'm installing the 2 piece swing arm. Should of brought a lottery ticket.
  4. #63
    Aug 2007
    Montreal subburb
    Yeah , I read your post in another thread
    => the pinched o-ring .
    Every Time You Lift Your Tank Beware Of This .
  6. #64
    Aug 2007
    Montreal subburb
    Quote Originally Posted by some 9 View Post
    I have the stock exhaust ......
    you are saying the hub can move enough to let me
    turn the 10 inch rim from the hub side whitout
    removing it
    ..I was under the impression that the hub was
    too big to fit in the cavity of the rim on the hub side
    I guess it could depend on the model of the rim
    my rim is the shape of the stock rim , it is a widened rim .
  7. #65
    Sep 2012
    Long Island, NY
    removing it
    Yes have done it with a stock exhaust, its tight put it will go .
  8. #66
    Aug 2007
    Montreal subburb
    Oh so nice , gotta love all this good info
    can't wait to try ,thanks some 9
  9. #67
    Sep 2012
    Long Island, NY
    BTW it's only 5 bolts to remove your stock exhaust
  10. #68
    Aug 2007
    Montreal subburb
    Ha Ha , there you go Andy, I was convinced on trying the secondary side this time
    and now you remind me how easy it is to remove exhaust , it will get done,
    and I guess I will decide how to do it at the last minute ,
    I'm finished thread jacking Lamont's thread now
  11. #69
    Sep 2012
    Long Island, NY
    Yep 4 bolts at the head and one at the very bottom, servo and bracket stays connected to exhaust
  12. #70
    Aug 2010
    Great NW
    5 bolts, ONE nut LOL
  13. #71
    Sep 2012
    Long Island, NY
    I stand corected it actually 6 bolts and 1 nut
  14. #72
    Sep 2015
    ark
    What o ring are ya'll talking about pinching? My bikes been apart for awhile now waiting on a new swing arm. I finally got it mostly back together and reading that got me worried.
    I am curious about the fit of the rubber boot on the swing arm. It doesn't seem to be to air tight.
  15. #73
    Aug 2007
    Montreal subburb
    Quote Originally Posted by riderguy View Post
    In another thread , Nemo mentionned he pinched the O-ring and he had a leak after that ,
    I'm assuming it is the O-ring in this picture
    there are also some alignement tabs I have read about ,
    you must put them back in same position .
Name:	5 enleve U-joint.jpg
  16. #74
    Sep 2015
    ark
    Ok. Thanks. After looking at the picture I might have put that boot on backwards. That sucks.
    Thanks for the help.
  17. #75
    Member jammerz's Avatar
    Apr 2014
    Mesquite, Texas
    I spent several hours with the help of my brother and couldn't get the driveshaft to slip back in place with the u-joint. Going to take another stab at it tomorrow but now I have two excellent ways of getting it done. Thanks M109 riders you've come through for me again.
Tags for this Thread
