Kuryakyn Grip Install - Page 5
Page 5 of 7 FirstFirst 1234567 LastLast
Results 121 to 150 of 209
Thread: Kuryakyn Grip Install
  1. #121
    Nov 2008
    West Valley City, Utah
    Quote Originally Posted by claymohr View Post
    Yes,
    The pics.
    They are no longer showing on this "how to".
    I looked at this thread thinking I could "see" what I needed to do! Anybody have a clue what happened to the pics?
  3. #122
    Very Active Member pdpdiamonds's Avatar
    Aug 2008
    Boston, MA
    Quote Originally Posted by twukker View Post
    just youtube it if the pics are not working any more. there's a few fellas out there that has done videos on it. really easy tho. there's a few vid links already in this thread if you check back.
    I installed mine in about 30 minutes (didn't have sandpaper to get rid of the old glue)
    To reach great heights, one must first conquer great depths.
    Arlen Ness Big Sucker Kit - Arlen Ness RADIII Teardrop Mirrors - Cobra Slashdowns - DynoJet PCIII - Kuryakyn ISO - (Parts ready to be installed: Debeaver Kit, GiPro, Factory Pro Shift Kit)
  4. #123
    Active Member loball's Avatar
    Apr 2009
    Canton, GA
    Installed the 6235 grips today approx. 30 minutes.
    Had one of those screws strip (even with the warnings and extra care), was able to get the grips on though !
    I haven't glued the clutch side yet, it was pretty tight fight, will determine if I need glue in the near future.
    '08 yellow LE
  6. #124
    Very Active Member jglass4763's Avatar
    Nov 2007
    Asheboro, NC
    I tried that, definately use the glue!!!
  7. #125
    MoCo Maryland
    Ok so can you take the throttle sleeve out of the 6235's and just slide the grip up on the stock throttle sleeve. I didn't know the universals worked and ordered bike specific. I would rather not have to fool w/ the sleeve if I don't have to.
    Anyone
  8. #126
    Mar 2007
    West Virginia
    Anyone
    There is no throttle sleeve on the stock grips, they are one piece, so if the universals have one you won't need to use it. The bars are 1", so as long as the ID of the universal grips are the same you just slide them on.
  9. #127
    MoCo Maryland
    Thanks, I sent the 6235's back today in exchange for the 6240's.
  10. #128
    Very Active Member WhiteStar's Avatar
    Sep 2008
    So Cal, Inland Empire
    Quote Originally Posted by jglass4763 View Post
    DEFINITELY NEED THE GLUE!!!
    "Don't worry about it rider"
    That one Man is the secret theme of the entire revelation of God to man through that which is known as the HOLY BIBLE... JESUS CHRIST.
  11. #129
    Rockdale, Texas
    Just put the iso flames on my 09. Part #6261 I believe. Very easy thanks to all the good advice in this thread. Had no problems with any screws. I put the brake lever cable side on first then twist the throttle back and open up the butterflies a little and the rider side cable has adequate room to slip in.
  12. #130
    Rockdale, Texas
    Another little tip. If you're having trouble with the screws, put a dab of valve lapping compound on the tip of your screwdriver. You won't believe how well the screwdriver will bite. It will allow you to input a lot of hand torque without slipping.
  13. #131
    Active Member Chris_FL's Avatar
    Nov 2010
    Pembroke Pines, FL
    Did mine today, here are my $.02.
    Don't forget that plastic sleeve. I did not see it and I installed it with it on the throttle side. I did not notice until I tried to put the switch box together. I had to undo it and reinstall it.
    And OMG that glue is strong!!!
    My dog got to the glue and bit a hole in it and I did not notice and that stuff got all over my hands when I squeezed it. Took me forever to get it off my hands.
    My tip: place the glue toward the top of the handle bar like the video above says. I put it on the whole handlebar and it got stuck before i was able to push it up all the way. It does set fast! Thankfully I was able to recover.
    All in all it was a simple install easy enough for anyone to do. Just be patient. Even with my headaches it look about 30 minutes,
    Thanks everyone.
  14. #132
    Very Active Member TORQ's Avatar
    May 2008
    SOUTHWESTERN NEW HAMPSHIRE
    Guy's whats the trick to get the pictures to come up??!!! I right click on the red X and the click on pictures and nothing!
    Owner of The Rarest M109R, THE 2006 Burple. THE ONE Suzuki Promised, TO NEVER make again!! Do to IT BEING, JUST to FAST for the General PUBLIC!
  15. #133
    Very Active Member Blakester71's Avatar
    Apr 2009
    Summerville, SC
    Quote Originally Posted by TORQ View Post
    red X means the picture is not there. some glitch with the way the person posted the pic.
  16. #134
    May 2008
    What alot of wasted work then, while trying to help, and show us How Too
  17. #135
    MoCo Maryland
    This thread is from 06. Maybe the O/P needed the space to host other pics or no longer has an account. Could be lots of reasons.
  18. #136
    May 2008
    Red face
    Perhaps but SUCKS! Sure wish they were there.
  19. #137
    Very Active Member dave340's Avatar
    Apr 2010
    Western Canada
    2011LE, not so stock anymore. Lots of plans, lots of time...
    "Ever notice how you come across somebody once in a while you shouldn't have fed with? That's me..." GT
  20. #138
    Very Active Member SilverScreamer's Avatar
    May 2007
    Default new write up needed...
    I just purcased some ISO Grips from DLP, Ill see about taking new pics and doing a new write up durring the process...
    2006 Silver m109R - Corbin Fairing & Saddlbags - Magellan Maestro 4250 GPS - Kury Iso Grips & Throttle Boss- Breakaway Cruize Control - Suzuki Engine guards -V&H Big Shots- PCIII -Shark 250W Amp - Bottlefed Cannons- JSD-3M - SS Front/Rear Break lines -Factory Pro Shift
  21. #139
    Very Active Member pynikal's Avatar
    Jan 2008
    Blue Springs, MO
    anybody have a DIY/How-To remove kury grips??
  22. #140
    May 2008
    Quote Originally Posted by SilverScreamer View Post
    I look forward to your how to, with pic's that work
  23. #141
    Very Active Member Gold5th's Avatar
    Dec 2010
    Athabasca, AB, Canada
    I'm debating between the 6235 and the 6240, the 6240 would go on like the ones I put on my virago, very simply.
    I just need to confirm that the 6250 throttle boss will work with the 6240's as well as a throttle lock, I'm looking at the 6218, but I see the 6329 looking quite interesting and less intrusive looking. I always wear gloves, so not sure how well the 6285 would work for me... they have a real funky one 6280, it's electro magnetic, and very pricy, but I think it makes the function more complicated.(oh it's for HD's booo, but you touch front or rear brake, or even the clutch and it'll unlock the throttle.)
    Oh and for the 6235:
    http://community.cruisercustomizing....588/22960.html
    Sure it's not a 9, but other than the screws on the start cover it looks pretty much bang on.
  24. #142
    May 2011
    San Antonio
    My turn.
    I'm going with the Iso grips also. I installed the throttle side first of course and now the switch housing won't close all the way. I'm pissed!
    I think that was is happening is, the part that sticks up where u attach the cables to, is too tall in the switch housing. It pivots on that part and won't allow it to fully close. It also makes the grip stick when you turn it. It won't return.
    It will if I take it all apart again to where the housing is hanging lose.
    The model is 6235. Should I sand/grind that plastic piece down?
    WELL DAMN! It closed and it sticks now. It's not pivoting on it. Yes i put the return cable back out but it still sticks.
  25. #143
    MoCo Maryland
    Quote Originally Posted by dre319 View Post
    My turn.
    you have something out of whack. I have the same grips, they fit/work fine.
  26. #144
    May 2011
    San Antonio
    Of course you do Big B! Your my inspiration for getting them. Lol
    Yeah there must be because even when I open the housing completely open, the return cable works.
    It's not until I close it altogether that it binds. Tomorrow is another day and I will mess with it then.
    So until then, thx.
  27. #145
    May 2011
    San Antonio
    Okay so I'm posting this for tech issues I guess.
    Turns out that the throttle grip had an issue fitting. I was able to put the new grip on and once it was on all the way on, it clicked and went on like half a centimeter on some more. There it couldn't go anymore.
    I took the grip off to look inside of it and there was no obstruction in it. I ended up grinding down the end of the handle bar a tad and now the new grip spins freely.
    So it wasn't the housing at all but the end of the inside of the new Iso grip.
    Just FYI
  28. #146
    Very Active Member Djm2u's Avatar
    Sep 2010
    Edmonton Alberta
    So I added the grips, stilleto ends and scyth 2 mirrors.
    After reading this tread was a little worried. But was able to do the install in about 30 min with no issues. Possibly the new version of the grips is better. I highly recomend getting a impact driver to remove the one screw 2 hits and it was loose.
    Thanks for the write up.
    2007 M109r Vance & Hines Exhast, Power Commander 3, K&N air filters, 280 on the rear, 160 on the front.
  29. #147
    Very Active Member Duende01's Avatar
    May 2009
    Clarksville, Tennessee
    I attempted to install my grips this evening after finishing the Irate Grill but could not get one of the screws off for the life of me. Now my question is; Is it necessary that all three screws are removed? I am having the hardest time removing the one in the middle and its head is stripping. I gave up until I find myself either a screw extractor or a dremmel to make the phillips into a flat head.
    Now, although it is past midnight here in Brussels, if someone confirms that it can be done without removing the middle screw, I will get back in the garage and give it another try.
    -2008 M109R "The Silver Bullet"
    -2013 HD Road King "The Orange Crush"
    -2015 HD Sportster Iron "TBD"
  30. #148
    Mar 2007
    West Virginia
    The two on the outside corners take the controls apart. The one in the middle holds a small plate on that holds the cables in position. It doesn't have to come off to install the grips providing you can get the cables off the old grips, which normally you can. You only need to remove the center screw if you're replacing cables.
    Back to the garage.
  31. #149
    Very Active Member CDM76's Avatar
    Jul 2011
    Grande Prairie, Alberta
    My turn.
    Having same issue ... took it apart twice. I see the little knoby thing sticking up ... but it was together alright with stock grips so it must be something small ... I just can't figure it out ! ! !
    EDIT: Disregard - I thought a filed down spot was where the little knoby was supposed to go ... I just had it aligned wrong as there is a drilled hole in the bar for it. Fits and works PERFECT !!!
    Thanks for the help SilverSurfer
    Posted on my BlackBerry Z30.
    __________________________________________________ _______________________________
    And the modding begins ....... Will it EVER end ?\
  32. #150
    Active Member kingskid72's Avatar
    Sep 2011
    Maryland
    Default Kuryakyn Iso flame installation
    I tried today to instal my new grips that just came in, and also swap my handlebars... i was doing pretty well until i tried to instal the throttle side grips and the housing wouldn't close all the way... i tried pushing it in all the way put it wont align with the stopper on the handlebars... and also when i tried to tighten it anyway.. the throttle wouldn't return...
    had to re fix the old one, which i had cut to rip open on the clutch side... so freaking upset right now.. what am i doing wrong?
