factory paint/clearcoat?
Thread: factory paint/clearcoat?
    Sep 2020
    Upstate NY
    Default factory paint/clearcoat?
    Getting ready to order up some spray paint to redo a couple of the radiator shroud pieces. Did our M109's come from the factory with a clear coat?
    Very Active Member StitchsLoft's Avatar
    Wellsville, NY
    Of course it does... Auto paint from a can is garbage. You need to get a two stage paint. You get what you pay for and there is a reason why it comes off so easily. most body guys will use like a PPG. That is expensive however. I suppose two stage in a can will be better than nothing but you can get an HVLP gun for pretty cheap. If you want your paint to look halfway decent use a gun or have a pain shop do it, even when I did my S.H.I.E.L.D. car in satin its just dulled down clear coat!
    ~Stitch
    2008 M109R2 AGENTS OF S.H.I.E.L.D. by STARK INDUSTRIES
    If you're color matching, go to colorrite.com. there is no paint code to match it but Colorrite matches perfectly. You'll have to select year and color you need. It's quality product.
    Sep 2020
    Upstate NY
    Thanks for your input guys, I was fortunate in that I just found the 2 pieces I needed on Ebay, so I won't be needing to paint after all.
    Wellsville, NY
    Quote Originally Posted by jobbyjim View Post
    Nice!
    ~Stitch
