My 2006 M109R wont start!
Results 1 to 11 of 11
Thread: My 2006 M109R wont start!
    Default My 2006 M109R wont start!
    Hello, i’m having issues with my bike Saturday i was working in the driveway and i started her up a couple of times to move it out of the way! Sunday i had a possible buyer comming to see it! When it came time to start it up it wouldnt start ! It just wouldnt turn over! I put gas because it was a bit low but still nothing! I checked my fuses all good i parked it in the garage (pretty cold now to leave it out) and fully charged the battery and still yet this afternoon it wouldnt start, i can here the pump, it juste turns but wont start! Any suggestions?
    Active Member Stalker's Avatar
    Apr 2020
    Quote Originally Posted by Themansandman View Post
    Did you have the tank off by chance?
    Quote Originally Posted by Stalker View Post
    Where is the switch? To be honest i’ve never turned it on or off but my daughter is always messing with the bike and she could have maybe by accident
    Apr 2008
    mass
    There is no switch,he means completely off the bike.are you pulling in the clutch lever it won’t start if you don’t,even in neutral.check the kickstand switch,how old is your battery ?
    Quote Originally Posted by k109 View Post
    Clutch is pulled in completely line was changed recently (worked fine since) the kick stand also lifted during my last attempts usually i put in neutral as to not have to lift it up! Still nothing! Battery was at 100% i had it plugged in to my smart charger to be sure ! I did not remove tank but i might try and flush the gas and check the line for any cloggs...
    Jun 2018
    Concord, VA
    Are you saying it turns over but doesn't start or doesn't turn over. You seem to say both in your post. If it's turning over then it is not any of the switches (clutch, kickstand, or kill switch). It's not getting fuel or not getting spark. If it's not turning over then it could be any of the switches mentioned above or check the ground wire from the battery. Does it say check in the cluster?
    Quote Originally Posted by UVATom View Post
    It’s turing over but isnt starting! I’m in the process of changing fuel filter (is there anotherone other than in the tank?) at the same time k might changed spark plugs for good mesure!
    May 2018
    Wellsville, NY
    Sounds like it doesn't want to be sold... LOL
    ~Stitch
    2008 M109R2 AGENTS OF S.H.I.E.L.D. by STARK INDUSTRIES
    Quote Originally Posted by StitchsLoft View Post
    yeah just wants me to spend more money on it! Jesus not given the spark plugs and fuel filter....
    Aug 2013
    Gardner, KS
    Remember even thought these are V-twin engines we have 4 plugs to change not 2.
    BOTM: SEPT 2016
    Quote Originally Posted by Mrtallguy67 View Post
    Why not!
