Not sure what I did - shock adjustment
Results 1 to 9 of 9
Thread: Not sure what I did - shock adjustment
    Jun 2020
    Glenview, IL
    Default Not sure what I did - shock adjustment
    I weigh 155 lbs and when I hit imperfections in the road the 109R knocks me around for example small humps in the pavement act like speed bumps and literally set me up out of my seat. Then there are the man hole covers that set 1 to 2 inches below the street - those should be fixed - kidneys outta my head.
    I have read about the preload but never messed with it as some of the posts seem to contradict one another. On the one hand many claim dialing down softened the ride but may lead to wallowing then on the other hand some posters claim it only serves to raise or lower the bike and has no impact on the smoothness of the ride - who knows.
    Well I can't take it any longer and I finally decided to do something; still reading the posts left me with a whiskey tango foxtrot with respect to the setting # on the shock. This afternoon, I removed the skid plate, from the right side of the bike head facing to the front I look at the shock. I could see the #s but have no idea what is what. So, with the spanning wrench and a rubber mallet I clicked the shock to the left as far as it would go. As best I can tell #4 is facing down - all I can really say is that I cannot click the preload anymore to the left. Not sure it is either better or worse but when I push down on the back it seems to have more rebound. We will see, can any tell me from the description above if I lessened the preload or increased the preload, I think I lessened it.
    Nov 2009
    CROWLEY, TX
    You stated you clicked the adjustment mechanism all the way to the left. Does that mean you clicked/turned it clockwise or counterclockwise? If my memory serves me right, turning or clicking the adjustment mechanism clockwise will increase dampening and lessen the stiffness. I made that same adjustment on my 07’ model back around 2009-2010, and as far as I can remember, the clockwise adjustment provides for increased dampening and less stiffness. For sure, you’ll be able to tell, once you get the bike out on the road for even a short 2-3 mile test ride.
    Mar 2007
    West Virginia
    If you are reducing the preload on the shock (i.e.; going from 4 to 1, the adjuster is easier to turn because it is going down a ramp and relaxing the spring. Going up is harder as the adjustment pin must climb the ramp and compress the spring. Changing the preload doesn't change the damping, it just changes the initial amount of tension the spring puts on the shock. Going down does lower the bike slightly. Preload is mostly used to adjust to the weight of the rider to give the bike the correct loaded ride height.
    If you can see a #4 facing down, you have it set on #1, or the softest setting. It does make it absorb bumps better, and I've never noticed any wallowing.
    Just for reference:
    #7 facing down is #4, the factory setting.
    #6 facing down is #3.
    #5 facing down is #2.
    #4 facing down is #1.
    Very Active Member Shadow721's Avatar
    Apr 2013
    Staten Island, New York
    Just curious. Is there a down side to setting the tension to #1? I’m 6’2” 295.
    Here for a good time, not a long time.
    Mar 2007
    West Virginia
    Quote Originally Posted by Shadow721 View Post
    Other than the slight lowering effect, not really. It might bottom just a little easier, but if you haven't lowered the bike you should just notice a softer ride.
    Apr 2015
    The Rose; Central Alberta
    I ride 2-up with my wife a lot. I'm about 230 and she is way way less than that. The shock setting from factor is WAY to stiff. I turned mine down to 2. I've never bottomed the bike out and the ride is better.
    May 2018
    Wellsville, NY
    I am 6ft and 240... Mine rides stiff as hell, are you telling me we can adjust that? LOL
    ~Stitch
    2008 M109R2 AGENTS OF S.H.I.E.L.D. by STARK INDUSTRIES
    Sep 2012
    Vicenza - Italy
    You may want to change the rear shock with an aftermarket one, which offers also hydraulic rebound control.
    I put a Wilbers one on mine and it changed the bike handling completely... More comfort and holding the line much better ✌️✌️✌&#xfe0f ;
    Woe to You Oh Earth and Sea for the Devil sends the beast with wrath because he knows the time is short Let him who hath understanding reckon the number of the beast for it is a human number its number is M109R.
    Jun 2020
    Glenview, IL
    Default Yes, it is better
    Quote Originally Posted by StitchsLoft View Post
    Cold weather set in before I could get the 9 out to test the ride. But, we had some warm days a few weeks back and I was able to get out. The ride is much smoother than before so it does make a difference. It did lower the bike a little as well - some posters said that would happen. Did not seem to affect the handling of the bike.
    Best,
    Glenn
