Electrical Question --Calculating Amp and battery draw
Thread: Electrical Question --Calculating Amp and battery draw
    Member gino33's Avatar
    Jul 2020
    Oakland, CA
    Default Electrical Question --Calculating Amp and battery draw
    I'm adding alot off accessories to my 2006 109.... radio, warming gear, usb charger, lights etc. Is there an easy way to ensure I am not putting to much strain on my battery/alternator? I assume I can add all the amp/watts draw from my accessories and make sure its less than my alternator but I assume there might be a simpler way... Any suggestions? Thank you!
    Super Moderator HyperPete's Avatar
    Adams County, Pennsylvania
    Lightbulb
    Here is an old thread that should help you:
    https://www.m109riders.com/forums/sh...d.php?t=122037
    - My memory's not as sharp as it used to be. Also, my memory's not as sharp as it used to be.
    - God grant me the senility to forget the people I never liked, the good fortune to run into the ones I do, and the vision to tell the difference.
    Detroit
    One thing you can do is start the bike, turn everything on and then measure voltage at the battery. If you don't get around 13-14 volts, you are drawing too much. Keep in mind you don't usually use everything at once. I shut everything off a few minutes before I get home just to be safe.
    Jul 2020
    Oakland, CA
    Thank you both!
    Have either of you used a Power Distribution Unit (PDU)? Wondering if it worth the $100+ investment compared to a $10 fuse block
    I added a switched fuse block on my FJR1300.
Name:	FJR1300 Fuse Block.jpg
