Only right turn signals work?
Results 1 to 6 of 6
Thread: Only right turn signals work?
    May 2017
    Dallas
    Default Only right turn signals work?
    I got some new led turn signals. This is not my first rodeo. I've installed several different sets of turn signals on this bike and never had a problem. I've had the flasher relay hooked up for over a year. I don't have hyper flashing. I hooked up the left front and it was working. Then I hooked up the right front. It was working. Then I switched it back to the left and nothing. I tested all 4 of the new signals and they all work. The left side doesn't seem to be getting power. Maybe the flasher relay is bad?
    Oct 2011
    Breslau, Ontario, Canada
    You could try tracing the wiring back up into the headlight bucket and check to see if the wire is grounding out or you pulled a ground out.
    2009 M109R LE
    2015 Boss tins, Custom speedo and tach faces and LEDs. ISO Grips. Brake Away Cruise control. Cobra Swepts. Debeavered, Fi200R Fuel management, polished risers and trees, SS Brake lines, ATRE, Custom forward controls. HID kit. Ultimate seat and backrest. Dunlop E3s, 250 rear, Plastidipped rims, cobra solo rack
    May 2017
    Dallas
    Quote Originally Posted by Fraps View Post
    Everything is already apart. The headlight bucket is off and I can see everything.
    May 2017
    Dallas
    May 2017
    Dallas
    I figured it out. There was no power getting past the gray connector in the pic. The flasher relay is good. I don't feel anything loose on the gray connector, but it refuses to let any current through even when I press on it. I can get power where the alligator clips are.
    Oct 2011
    Make sure the pins inside haven't broken. Maybe take that connector apart and clean the terminals, check for corrosion or just a poor mechanical connection. Check all connections (soldering or taps) from where you have power down. Seems like you know what you're doing. Confident you'll find the issue.
    2009 M109R LE
