Kickstand sensor killing bike
Thread: Kickstand sensor killing bike
    Active Member Vytasb's Avatar
    Southern California
    Default Kickstand sensor killing bike
    The kickstand is slightly coming down over bumps occasionally and it kills acceleration. Should I just replace the springs or is it something else?
    2012 M109R Limited - Spike Intake w/cone filters, Velocity Pro, X-TRE, PowrPro Black
    Active Member StuporDave's Avatar
    May 2017
    Tulare, ca
    I never had a problem with my kickstand switch, but I eliminated it when I got the bike because they always piss me off. Take the switch off, cut off the connector on the bike harness, solder the wires together, cover in heat shrink. You could use a crimp cap. They are usually white and are like a butt connector but only open on one side. Then heat shrink.
    Breslau, Ontario, Canada
    Removing the kickstand switch is a safety issue and if you need any sort of inspection down the road, your bike will probably fail.
    It's likely the connector is loose or full of crud/corrosion. Take it apart, clean it, inspect the wires and check for obvious issues to correct.
    2009 M109R LE
    2015 Boss tins, Custom speedo and tach faces and LEDs. ISO Grips. Brake Away Cruise control. Cobra Swepts. Debeavered, Fi200R Fuel management, polished risers and trees, SS Brake lines, ATRE, Custom forward controls. HID kit. Ultimate seat and backrest. Dunlop E3s, 250 rear, Plastidipped rims, cobra solo rack
    Very Active Member Fishman349's Avatar
    Mar 2013
    Calgary, AB
    "The kickstand is slightly coming down over bumps." Has someone seen this happen? If so, replace the spring and do what Fraps said. I've never heard of another 9 having that problem but there is always a first. Good Luck!
    H.C. Velocity Pro, Cobra Power Pro Black, Cobra Engine Guards, ISO Blk Grips, National Cycle VStream Tour, Kuryakyn Switchblade Pegs, G/M TRE, .....
    Member Jeffro109's Avatar
    May 2016
    Las Vegas
    I had this happen on my Gixxer. The ‘ears’ where it mounted were spread a little and let it shift. I took it off and closed them a little with a hammer, perfect after. I don’t recall how ours mount though.
