clutch setup
Results 1 to 2 of 2
Thread: clutch setup
    Nov 2013
    Edmonton Canada
    Default clutch setup
    i have a 2009 m109r and i redid the clutch plates but am wondering how to actually set the clutch up so that the clutch lever and clutch are set properly. on the left side of bike i can adjust the lever cable but i see nowhere to adjust clutch. usually u loosen a 10mm bolt and turn screw in and then back off 1/4 turn but i cant see that anywhere.. can someone help
    Nitra, Slovakia
    Quote Originally Posted by Goliath442 View Post
    There is that adjustment screw in the n middle of the clutch, all the info you
    will find in the service manual. If you dont have one, download it from here:
    Main service manual:
    https://www.manualslib.com/download/...r-Vzr1800.html
    Supplemental manual 2010/11 and UP:
    https://www.manualslib.com/download/...i-Vzr1800.html
    Owners manual:
    https://www.manualslib.com/download/...zr1800-Bz.html
