Speedometer freaking out
Results 1 to 12 of 12
Thread: Speedometer freaking out
    Member Joe_Petro's Avatar
    Aug 2018
    New York
    Default Speedometer freaking out
    Hey all I have a quick question for you guys. I went for a 4hr ride today and I realized while I was doing 75-80 mph the speedometer would freak out and go to 100 down to 60 then back to my actual speed.
    I did just get new tires installed please help me out .
    Thanks in advance
    Super Moderator HyperPete's Avatar
    May 2008
    Adams County, Pennsylvania
    This sounds like the speedo sensor needs to be cleaned. Take a look at the following thread:
    https://www.m109riders.com/forums/sh...8155&p=1791017
    - My memory's not as sharp as it used to be. Also, my memory's not as sharp as it used to be.
    - God grant me the senility to forget the people I never liked, the good fortune to run into the ones I do, and the vision to tell the difference.
    Very Active Member blacklightning's Avatar
    Oct 2007
    Apex, North Carolina
    I had that to happen to my 07 years ago. After doing about 2-3 start ups and recycles, it never did it again.
    Aug 2018
    New York
    Thank you for giving me this i am going to try it this weekend and see if it works
    Thank you
    Aug 2018
    New York
    Blacklightning thanks for that I am going to try a all of your suggestions it was driving me nuts 😜
    Thanks again
    May 2008
    Quote Originally Posted by Joe_Petro View Post
    Thank you
    You're welcome! I also had a bouncing speedometer which was resolved by cleaning the sensor.
    Note: a tablespoon or so of oil could possibly drip out when you remove the sensor, so you may want to put a cup or a rag underneath while cleaning it.
    Lastly, the advanced search feature works very well. There is a lot of information here if you search. Someone will usually answer your questions quickly, but searching is even quicker!
    You can also use Google to search the site by entering your search terms and adding site:m109riders.com
    Good luck, and cheers!
    Jun 2018
    Concord, VA
    It is just metal flakes on the sensor since it's a magnet. Cleaning it will solve your issues. How old is the bike? If it has a lot of miles then you should listen for some noise in the secondary area. There is a bearing in there that could wear which might be where the metal is coming from.
    Aug 2018
    New York
    Quote Originally Posted by UVATom View Post
    My bike is a 2017 with not even 6k on it. This is the first time seeing this, I did just change the tires would that make it freak out ?
    Aug 2018
    New York
    Quote Originally Posted by HyperPete View Post
    Thank you
    So when I pull out the sensor and oil comes out should I replace the oil or clean it and put it back dry ?
    Apr 2006
    Traveling America
    Long enough for the break in period.
    Coming to a city near you..
    Bang for the Buck Mods link
    CLICK HERE
    Apr 2006
    Traveling America
    Clean it and re install the sensor. Any oil that you lose will be negligible.
    CLICK HERE
    Aug 2018
    New York
    Thanks for everything will check it out on Thursday
