TRE and Servo Eleminator
Results 1 to 3 of 3
Thread: TRE and Servo Eleminator
    Jul 2020
    Wanganui New Zealand
    Default TRE and Servo Eleminator
    Forgive if its been asked before, is there any benefit to be had by fitting a TRE and a servo eliminator to a totally stock bike? IE stock exhaust and air filters etc? The TRE I would say yes but how about a servo eliminator? Would this just hold the valve fully open all the time? I presume the same things can be done with a flash but getting someone here in NZ to flash an ECU is near impossible.
    Cheers.
    Jan 2009
    Nitra, Slovakia
    Quote Originally Posted by DakS83 View Post
    Cheers.
    Read about servo eliminator here:
    https://www.skutr.net/exhaust-valves...ors-explained/
    Jun 2013
    GA
    Cheers.
    TRE is a must if flashing isn't an option. The servo eliminator is simply to fool the ECM into believing it's still there. If you have stock pipes then it's likely a waste of money plus you would have to open the exhaust valve and pin it open because the cables from the original servo would no longer operate the valve.
    '19 M9 '06 M9
    '09 commander
