Coolant
Results 1 to 11 of 11
Thread: Coolant
    Member XVTX Rider's Avatar
    Feb 2020
    Phoenix, AZ
    Default Coolant
    Can I use Honda HP Coolant in my M109R? I have 3 quarts from when I had my VTX.
    Tha
    Jan 2009
    Nitra, Slovakia
    May 2019
    Quote Originally Posted by XVTX Rider View Post
    Tha
    Yes, it is essentially the exact same long term high performance fluid according to the dealer`s mechanics .
    I cleaned, flushed the whole system and replaced the fluid on my 9 with this one and it has ran perfect ever since .
    One thing, thou : I replaced the whole fluid amount , so I did not mixed it with the old fluid .
    Feb 2020
    Phoenix, AZ
    Thanks, I was hoping to be able to use it since its $10 a quart.
    Jun 2013
    GA
    That's expensive!! Especially when it all taste exactly the same.
    '19 M9 '06 M9
    '09 commander
    Jul 2020
    Wanganui New Zealand
    Quote Originally Posted by Frotosride View Post
    lol, tastes the same, as a side note, if you have cats DONT ever leave coolant lying on the ground, the little buggers love the taste of it but its deadly poisonous to them.
    Dec 2007
    Toronto, Ontario, Canada
    Default Best way to flush rad/cooling
    What is the best way to flush the rad and coolant in the motor ?
    May 2019
    My guess will be to disconnect the lower hose on the radiator and go from there .
    Jun 2018
    Concord, VA
    You drain it, fill it up with a distilled water and vinegar mixture or a flush you buy (follow the directions and make sure it's safe for Alum) and then run it for a while. Drain it again and fill it with distilled water. Run it and drain it again then fill with coolant. Don't forget to clean the overflow bottle too.
    Dec 2007
    is there some way to 'back flush' the system ?
    Jun 2018
    Concord, VA
    The bike needs to get up to temperature and open the thermostat for it to cycle through the motor. It's not that hard to do. Since it's summer just drive it a day or so with the flush then drain it.
