Cyclops H4 Ultra problem
Results 1 to 7 of 7
Thread: Cyclops H4 Ultra problem
    Active Member
    Mar 2015
    England
    Default Cyclops H4 Ultra problem
    Hi, just fitted the cyclops H4 ultra bulb to bike, very bright, but when I pull the clutch lever in the high beam lights up.
    It's not done this with the standard bulb and all I've done is swap the bulbs.
    Any one else had this with this bulb or any ideas.
    Jan 2009
    Nitra, Slovakia
    There was once described here similar problem, when
    clutch lever pushed in the yellow "flash" button...
    make sure that is not your case as well...
    Active Member
    Mar 2015
    England
    [QUOTE=thevili;4003120]There was once described here similar problem, when
    Anyway /QUOTE]
    Bloody hell buddy good call, that's exactly what it was.
    Anyway the switch has been stripped and cleaned 😊
    I love the info on this forum.
    Jun 2013
    GA
    [QUOTE=The Prospector;4003122]
    Anyway /QUOTE]
    Amen to that! You can't beat the simple ones when someone had already been there, fixed it and cost nothing but some time!
    '19 M9 '06 M9
    '09 commander
    May 2018
    Wellsville, NY
    Beat me too it.... LOL
    Often late at night I often hold that bad boy down to get BOTH beams!!
    ~Stitch
    2008 M109R2 AGENTS OF S.H.I.E.L.D. by STARK INDUSTRIES
    Jun 2013
    GA
    Quote Originally Posted by StitchsLoft View Post
    +1 on that and add in the switchbacks and you're in business!
    '19 M9 '06 M9
    '09 commander
    Active Member
    Mar 2015
    England
    Get the cyclops ultra and you get both beams on main anyway
