Clutch replacement
Results 1 to 14 of 14
Thread: Clutch replacement
    Jan 2018
    Delhi, Ontario
    Default Clutch replacement
    So my newly purchased beautiful 09í needs a clutch. On the test ride anything over half throttle and the clutch slips.... and yes Iíve checked the cable on both ends for adjustment
    Iím very good with a set of wrenches but this will be my first time doing a wet clutch on a bike and looking for the proper way of replacing the clutch plates, I intend on buying OEM parts as well
    I remember seeing at one time the new plates need to pre-soak in oil, but for how long? 24 hours?
    Anything else to check while I have the right cover off?
    Thanks for any advice
    Jul 2008
    Forney, TX
    Quote Originally Posted by Chrispy View Post
    I soaked mine for 24 hrs in a Tupperware container.
    Nov 2009
    ARLINGTON, TX
    Chrispy, if you havenít already, you may want to seriously consider purchasing an 11í year model or newer set of clutch plates and springs for your replacement. 2011 was the first year Suzuki upgraded the clutch plates and springs to prevent the clutch shudder and hard shifting from 1st to 2nd gear that many had experienced with the 06í-09í models. The cost is not much different, but the results could be astronomically different.
    Active Member Gary E's Avatar
    Aug 2016
    Kansas
    Unrelated question, but what exhaust is that?
    Jan 2018
    Delhi, Ontario
    Is that all that is needed for the upgrade? Just the clutch plates and springs?
    This idea was on the back of my mind but wasnít sure of exactly what was needed
    Jan 2018
    Delhi, Ontario
    Quote Originally Posted by Gary E View Post
    I bought the bike as you see it, so if you or anyone can tell me what exhaust it is, Iíd love to know too lol
    Apr 2014
    Chesterfield, VA
    https://www.m109riders.com/forums/sh...d.php?t=297921
    Nov 2009
    ARLINGTON, TX
    This idea was on the back of my mind but wasn’t sure of exactly what was needed
    My understanding is all you’ll need are the clutch Plates and Clutch Springs, unless there are other components within your clutch assembly that need to be replaced, due to wear/improper functioning. I’ve added a link to Oneida Suzuki that may help you. Also, you can do a search on this Forum on this topic, in which all the necessary parts are listed.
    NOTE***I edited this post, because I think I was wrong about the number of Clutch Plates and Springs required.
    https://www.oneidasuzuki.com/store/p...109r-2015.html
    Jan 2018
    Delhi, Ontario
    Thanks for the link Poseidon, seems easy enough for the upgrade
    Judah, Iím planning to tear into the bike in a day or two to make sure itís only the clutch plates that need to be replaced before ordering parts, hopefully I wonít find any surprises lol
    Sep 2012
    Vicenza - Italy
    You may want to consider replacing also the clutch's sleeve hub with the 2011 on part.
    One out of the 5 spring is held in place and this reduces vibrations and noise considerably at idle - I did on my 2007 model and the bike is much more silent at idle
    Woe to You Oh Earth and Sea for the Devil sends the beast with wrath because he knows the time is short Let him who hath understanding reckon the number of the beast for it is a human number its number is M109R.
    Jul 2018
    Houston Texas
    Default 2008 C109R Clutch
    Quick question....are the clutch plates on a C the same as the M
    Dec 2007
    Toronto, Ontario, Canada
    Default Is the PIN mod needed if upgrade clutch plates ?
    I'm having periodic clutch issues and am considering replacing the clutch on my '07. I was wondering if I do replace clutch with the newer clutch plates, do I still need to do the pin mod (ie: grind down 3 surfaces on the pin) ?
    Same. I got a used 2016. No idea what exhaust I got.
    Jan 2018
    Delhi, Ontario
    Finally received my clutch parts and ready to get to work on it tomorrow!
