Final drive hot
Results 1 to 6 of 6
Thread: Final drive hot
    Active Member
    May 2014
    canada
    Default Final drive hot
    Just an FYI. I posted about a hot final drive as in hot enough I couldn’t hold my hand on the final drive for 3-4 seconds. Changed oil , no visible filings and nothing out of the ordinary. Another 200 km ride with a few stops and kept checking for heat. I couldn’t touch the final drive for even 1second. Not overly hot that day and no extra weight. Anyway I pulled the back wheel off and checked wheel bearings... they’re shot and transferring heat to the final drive. Wanted to let everyone know it’s something to consider if you’re having a heat issue with your final drive. 55000 kilometres on the bike.
    Very Active Member MrBarros's Avatar
    Mar 2020
    Boston, MA.
    Quote Originally Posted by bmac View Post
    Good to know BMAC, thanks for sharing. That's what it's all about getting all the info on the Nine onto this forum.
    Dec 2007
    Toronto, Ontario, Canada
    Shot wheel bearings .. how many miles/kms on the bike ? I can't say that I've heard of worn bearings.
    Feb 2009
    Oklahoma City
    Quote Originally Posted by asillito View Post
    Yeah, me either. And here I am riding a 14 year old M109R and I've never even bothered to put my hands on the "pumpkin". Never will. Even though it's overkill, I change the final drive oil every time I change the engine oil. It's only like 10 ounces or some small number like that. I use the same 75/140 that my Lightning takes, since I always have some in the garage. Only takes a few minutes and you can do it while waiting for the crankcase to finish draining.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Active Member
    May 2014
    canada
    Cool
    about 32000 miles/ 55000 kilometers. I found it odd as well. I change final drive oil every year. I took the bike for a ride to warm everything up before a engine and final drive oil change. During the oil change I noticed that the pumpkin seemed warmer than it should be which made me check it frequently. I went for a ride with a couple buddies with 109's and checked their final drive temperature against mine. Theirs was warm (could keep my hand on it without any problems) mine was so hot you couldn't touch it for a second. Anyway pulled the back tire off to check things out and found the bearings were grinding badly. They are a sealed bearing. I couldn't find anything that would suggest that there is anything else failing. I guess those bearings were just at the end of their life. Will see if I find anything else wrong in there and make sure to post any findings.
    Active Member
    May 2014
    canada
    an update on the final drive heat issue. after taking it to a local shop they shot the temperature and said that its normal to be 140-160 degrees F. i said no it was way too hot. They didn't want to take my money to tear it apart and find out so I took it to another shop. They were more than happy to pull it apart to find out that the main bearing in the final drive was actually broken and the spacers were shot as well. Not sure how it happened as I am very careful with service. If you ever feel excess heat coming off the final drive its worth getting checked. My buddy has the same bike (with less miles) and his final drive was warm to touch as you could keep your hand on it no problem...mine was too hot to touch for 1 second. thinking back I think I noticed the heat on my leg when leaning on the bike when we were parked for a coffee and noticed the heat coming off of it. Anyway hopefully this could help save someone from a wreck in the future.
