Somebody ever installed the Healtech X-TRE Power Box?
Results 1 to 3 of 3
Thread: Somebody ever installed the Healtech X-TRE Power Box?
    Active Member Erwin K's Avatar
    May 2010
    Kinderdijk (Windmills), Holland, Europe
    Question Somebody ever installed the Healtech X-TRE Power Box?
    New owner of a 2015 BOSS.
    Planning to install a X-TRE.
    Does one have to install the supplied wire harnas as well?
    Little afraid about cutting the ECU wires as suggested in the manual.
    2015 M109r BOSS
    Jan 2009
    Nitra, Slovakia
    Quote Originally Posted by Erwin K View Post
    Yes, you need to install it as per manual. Maybe a friend
    skilled in wire cutting and soldering will help you. It is not
    difficult at all. Otherwise get professional do it.
    May 2019
    Just make absolutely sure which is the wire to cut and to solder . It is not difficult but you need to be neat about it .
