Insert of a 'little' restrictive pipe inside Cobra Speedster Swepts exhaust?
Results 1 to 9 of 9
Thread: Insert of a 'little' restrictive pipe inside Cobra Speedster Swepts exhaust?
    Active Member BorderlandBiker's Avatar
    Feb 2015
    Moss Landing Californa
    Default Insert of a 'little' restrictive pipe inside Cobra Speedster Swepts exhaust?
    Has anyone increased their midrange with weeeee bit more back pressure? P.S. gettin' old's a bummer hopefully the new knee with get me riding again
    Dec 2007
    Toronto, Ontario, Canada
    Initially I found the baffles on my Cobras where too loud. I got the 'quiet cores' baffles and am much happier. These quiet cores increase the back pressure thus baffling the sound a little bit. These quiets cores may be what you are looking for.
    Feb 2015
    Quote Originally Posted by asillito View Post
    I believe your quiet cores is the way to go. In the mean time I was able to find a used Cobra Speedster Swept exhaust on-line for $200. When they arrived by UPS I found all the pieces fit BUT they had melted/baked (maybe a grocery or dry cleaner bag) plastic, on them. When I say baked I mean that after I installed them I tried taking the plastic film off after the bike had been ridden (It worked for some of it) and then I got some reeeleeee toxic brake cleaner (It worked for some of it)...I then said "what the Hell" and spray painted some high heat fireplace flat black over the spots after I sanded the surface. After I installed the insert in the 'lower' pipe I noticed an improvement in midrange immediately. I will try to attach some photos of the parts I used...PEACE RIDE SAFE...
    P.S. I know that Harley riders would bend the 'flanges' inward on their Thunderheader exhausts to improve the midrange (can't find the youtube video showing how they did it)
    Feb 2015
    My photos were not the best so I'll retake them...HOWEVER the good news is that between about 2500 and 4500 there was quite an improvement...reeeleee quick with no hesitation...The downside is the exhaust won't win any beauty contests...(removal of the baked on plastic bag...and using some high heat flat black paint to cover up where I finally had to sand the baked plastic off)...oh, well I can't complain for $200...STAY HEALTHY & RIDE SAFE
    Feb 2015
    I was able to contact Suzuki tech support through their home office 800 number...I was lucky. Normally they'll refer you back to your local dealership. I was told the M109's 'stock' fuel management chip was designed to operate from sea level up to over two miles...San Francisco to the top of Pikes Peak...They were very guarded about recommending 'other' exhaust systems, which made sense since the EPA now seems to be hiding under every rock. I did coax a thumbs-up from the technician for the Cobra Speedster Swepts with their crossover pipe. He seemed to have direct experience with them and said "they should work fine". He said the 'stock' fuel management chip would take about 20 miles and a few hills under different loads to re-calibrate to the Cobras...P.S. I'm still looking into the 'quiet cores' and have removed the 'insert'...PEACE RIDE SAFE
    Dec 2007
    Default 2 into 1 ???
    I've seen a bunch of posts about getting slightly better performance from a 2into1 pipe. You may want to consider that too.
    Jun 2020
    Alton, IL
    I just have a question. Where did you find that front turn signal stay in the pictures? I am slimming down my M90 and I have been looking for a solution to remove my front turn signal lights and replace them with fork ring LEDs.
    Feb 2015
    Quote Originally Posted by BorderlandBiker View Post
    Use only enough (you don't want to take away from your higher rpm power) of a restriction to give you just enough back pressure to get you over the 2500-3000 hump. The Suzuki tech (getting him to answer was like asking for Colonel Sander's secret herbs & spices) was right about the M109's fuel management system having a lot of latitude especially with the crossover pipe used in the Cobra swepts...soooo far so good. No surges...no backfires...PEACE RIDE SAFE
