Oil leak from secondary gear housing
Results 1 to 6 of 6
Thread: Oil leak from secondary gear housing
    Default Oil leak from secondary gear housing
    hello all i seems there is a leak from the secondary gear housing where the drive shaft goes into maybe a seal is this an easy fix or can i expect an expensive job
    Jun 2018
    Concord, VA
    It is not that bad to take off and a little harder to reinstall but the bearing is probably what caused it to go bad. You should listen for noise in that area while riding but you won't know for sure until you take it off. It does take a special tool to replace the seal so I shipped mine to futurR to be rebuilt since my bearing was bad. He can get the bearings cheaper than replacing the whole unit.
    Jun 2018
    Concord, VA
    There is a step by step in the how to section.
    Cant seem to find the tutorial
    Jun 2018
    Concord, VA
    Reinstalling driveshaft to u-joint https://www.m109riders.com/forums/sh...ad.php?t=67353
    It's also in the service manual which can be found on the forum.
    Member Fathan Medium's Avatar
    Jun 2020
    UK
    Thumbs up JThe same trouble
    i tink it's a big toublr. cause you have to repair it early.. Just to avoid your machine broken down
