Lift Table Chock
Page 1 of 2 12 LastLast
Results 1 to 30 of 31
Thread: Lift Table Chock
    Jul 2008
    Forney, TX
    Default Lift Table Chock
    I picked up a HF lift table this weekend. I'm needing to get a chock to be able to load and strap down the bike on my own. I saw this one in the link below. It had good reviews and the price is right. Some have stated that there finder would hit the rear of the chock. But that wasnt on a 9. Wondering if anyone has had any experience with iy.
    https://www.amazon.com/Extreme-Max-5.../dp/B00GRRFLOK
    Sent from my SM-T580 using Tapatalk
    Jun 2006
    Indianapolis, Indiana
    Yes, that style will damage a fender if you have an aftermarket draping fender. If you have a stock fender there are no worries. Also, you could search for a motorcycle wheel clamp that can be added instead. It will be ok with a draping fender. You just push the bike on the lift and hold onto the left handle bar and then tighten the clamp. I have 2 higher end lifts with the clamp and no issues after a decade.
    Jul 2008
    Forney, TX
    Ok thanks. Still have the OEM fenders. Ill look at those style of chocks you mentioned earlier also
    Very Active Member crazytrain's Avatar
    May 2006
    manakin sabot va
    Condor wheel chock, works great! I put my bile on it all the time. drive on and walk away! it holds the bike in place no clamps! Easy button!
    Sent from my SM-G965U using Tapatalk
    Tempting Fate, One 9 at a Time!
    Super Moderator HyperPete's Avatar
    May 2008
    Adams County, Pennsylvania
    I use the very similar Harbor Freight chock in my trailer. One note - if you run a 160 up front, it WILL squeeze the tire. I never had a problem with it, but it does not look good when it's getting 'squished."
ID:	388130 Click image for larger version.
    https://www.harborfreight.com/motorc...ock-69026.html
    - My memory's not as sharp as it used to be. Also, my memory's not as sharp as it used to be.
    - God grant me the senility to forget the people I never liked, the good fortune to run into the ones I do, and the vision to tell the difference.
    Active Member Stalker's Avatar
    Apr 2020
    Quote Originally Posted by crazytrain View Post
    I will second that for Condor chocks, they are great.
    Have these in the link below in my trailer and they work just fine with the larger front tires as well.
    https://www.condor-lift.com/SC-2000
    Not all Condor chalks will accommodate the larger front tires so you have to know which one you are buying.
    Nov 2009
    ARLINGTON, TX
    That is a very good chock. My good friend ZZUKE10 has one mounted in his bike trailer, but it does not work well with the longer front fenders, such as the Low & Mean Stealth Front Fender and the Barons Gangster Front Fender. That Chock will very likely chip and/or crack the bottom edges of the longer fenders, but it works perfectly for 9s that have the Stock Fender installed.
    Jul 2008
    Forney, TX
    CJ, do you leave you bike in the chock without strapping down?
    I have this Condor that I got from HUFF. But the attachment points are to wide for the table and I dont want to drill holes in the chock either. I looked to see if I could use just the center section but I couldnt tell.
    Jul 2008
    Forney, TX
    Quote Originally Posted by HyperPete View Post
    Pete, does that chock allow you to strap it down by yourself?
    May 2006
    manakin sabot va
    Dont strap it down for every day parking on the table. But i do only when for example change out motormounts, rear tire etc. Have the condors on my trailer and i do strap them down when travling. but for just parking no strap needed. it will hold the bile by itself, and i have the 160 on the front.
    Apr 2018
    Maryland
    I’ve used baxleys in the past for my sport bikes, they are awesome. I have the condor chopper chock now. I have a 23” wheel with long fender so I needed that one. I have my bike parked in that chock 24/7 with no straps. It ain’t going anywhere
    Jul 2008
    Forney, TX
    Thanks. Do you swap that jack over to your trailer to use as well?
    May 2006
    manakin sabot va
    no. Have two mounted in trailer, one on the table. The mount that comes with the table is just scrap metal!
    Jul 2008
    Forney, TX
    Quote Originally Posted by Bigpapa View Post
    Awwsome thanks. Guess I need to get one to fit the table.
  17. #15
    Jul 2008
    Forney, TX
    Thanks. I have the silver one like you have in the trailer. Looks like Ill start pricing one of those.
  18. #16
    Nov 2015
    I use a Condor chock on my Harbor Freight lifts. You will need to make side extensions unless you have very long legs. I use 2 x 6s. On one lift I have them attached to the lift and they are removable. On my other lift I use blocks and pin (long 1/2" bolts) the 2 x 6s to the blocks. The lift with the attached 2 x 6s works the best because the extensions are more stable.
  19. #17
    Jul 2008
    Forney, TX
    Quote Originally Posted by Metalman View Post
    Do you happen to have pics of the extensions? Curios on how they attach.
  20. #18
    Nov 2015
    The lift with the attached sides is in FL and I'm in KY for the summer. I will make a sketch and post it tomorrow.
  21. #19
    Jul 2008
    Forney, TX
  22. #20
    Nov 2015
    Default Lift Tabe 2 x 6 Extension Sketch
    The left extension must be removed to activate the lift pedal.
  23. #21
    Jul 2008
    Forney, TX
    Ok I think I understand. You are basically welding and attaching the 2 rods on each side and the 2x6 lays on top, correct?
  24. #22
    Nov 2015
    Actually I use three rods on each side. Yes the 2 x 6 is on top of the rods. I designed it that way because of the material I had in the shop. Each rod has two mounting tabs and each square tubing has two mounting tabs.
  25. #23
    Feb 2009
    Oklahoma City
    I have two Baxley Trailer Sport Chocks. One for the Nine and the other for my B-King. Neither hits the fender. Didn't hit the fender when I had an aftermarket Reaper fender on my Nine either. The Sport Chock is only good up to a 130 front, supposedly. I haven't had an issue with a 140 yet. Second picture is with a 140 front. In the third picture, you can see where the rear of the chock is narrower than the fender, so it went up inside the fender. Never caused any issues.
ID:	388226   Click image for larger version.
ID:	388228   Click image for larger version.
ID:	388230   Click image for larger version.
ID:	388232   Click image for larger version.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
  26. #24
    Jul 2008
    Forney, TX
    I have two Baxter Trailer Sport Chocks. One for the Nine and the other for my B-King. Neither hits the fender. Didn't hit the fender when I had an aftermarket Reaper fender on my Nine either. The Sport Chock is only good up to a 130 front, supposedly. I haven't had an issue with a 140 yet. Second picture is with a 140 front. In the third picture, you can see where the rear of the chock is narrower than the fender, so it went up inside the fender. Never caused any issues.
    Cool. Ill look that chock up.
  27. #25
    Very Active Member Shooter's Avatar
    Jan 2012
    Hillsboro Missouri
    Baxley makes a Chock specifically for a big bike. I've used mine on the 9 and my F6B. Works great on both. Ride on and step off. They make a bracket to mount it and what's nice is two bolts and you can move it from your lift to your trailer. It's pretty slick.
  28. #26
    Feb 2009
    Oklahoma City
    Is it Baxley or Baxter? Just looked it up and for sure it's Baxley. My error. Haven't looked at the metal tags on them in years. OOPS!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  29. #27
    Jan 2012
    Hillsboro Missouri
    Baxley
  30. #28
    Jul 2008
    Forney, TX
  31. #29
    Very Active Member blacklightning's Avatar
    Oct 2007
    Apex, North Carolina
    Harbor Freight actually sells a similar chock that I have used for years on all 4 M109's and every other bike that I have had. Last fall I bought another one to mount to a trailer to folding 2 bike trailer that I picked up. I am using it to lock in the spyder in the event that I should ever want to trailer it.
  32. #30
    Very Active Member MR.X's Avatar
    Mar 2010
    L'Islet, Qc, Canada
    Does anyone know if we could chop the swivel tong ( not sure about using the good words but the swivel stopper ) and make the condor fit on gangster fender?
