HELP Clutch issue maybe
Results 1 to 4 of 4
Thread: HELP Clutch issue maybe
    Default HELP Clutch issue maybe
    I just purchased a 2009 C109RT and when I’m coming off the clutch to roll/go in first gear the back tire jumps. Any idea what this could be causing that to happen? I could really use the help as I’m new to the cruiser game. Thanks in advance I’d you are able to help.
    Bike has 45k on it.
    May 2006
    My clutch use to grab suddenly after starting out from a stop and turning left and sometimes right. This went on for years. One day when I had my gas tank off, I noticed the clutch cable, where it comes out of the top opening in the shroud that sorrounds the radiator, was wearing into the plastic. I took a cable tie and pulled the cable to the side to prevent anymore wearing. I found this stopped my clutch from grabbing. Maybe this will help you.
    Nov 2018
    Ballarat Victoria Austalia
    [QUOTE=psmith;3994926]My clutch use to grab suddenly after starting out from a stop and turning left and sometimes right. This went on for years. One day when I had my gas tank off, I noticed the clutch cable, where it comes out of the top opening in the shroud that sorrounds the radiator, was wearing into the plastic. I took a cable tie and pulled the cable to the side to prevent anymore wearing. I found this stopped my clutch from grabbing. Maybe this will help
    Eliminate all the inherent problems of cable operated anything Install a hydraulic clutch Kit IN STOCK HYDRAULIC CLUTCH KIT C109/M109 $440USD INCL SHIPPING WORLDWIDE $575AUD INCLUDES SHIPPING AUSTRALIA WIDE CONTACT [email protected] PayPalClick image for larger version.
ID:	387006Click image for larger version.
ID:	387008Click image for larger version.
ID:	387010Click image for larger version.
    Jul 2008
    Forney, TX
    Quote Originally Posted by NewKidOnTheBlock6 View Post
    Bike has 45k on it.
    Search clutch shudder. There is a fix. Its due to lack of oil getting to the clutch pack.
