Greggs vertical sidemount
Results 1 to 9 of 9
Thread: Greggs vertical sidemount
    May 2019
    N/A
    Default Greggs vertical sidemount
    Hey guys, tried the search (because I know someone is gonna say it lol). Just got my plate mount in, came with the 14mm hex bolt n 3 washers for mounting. I have 2 questions:
    1) Did you guys use all the washers n if so in what layout? Between the bolt n mount, between mount n diff, both?
    2) do regular "license plate" nuts and bolts work? Wanna order something aesthetically pleasing, black spikes or black covered bolts to match the boss.
    Was gonna message Gregg but looks like he hasn't been active on here in a while. I could be wrong. Thanks in advance
    Sent from my SM-N950U using Tapatalk
    Very Active Member tcolt45's Avatar
    Jan 2015
    Frederick, MD
    on my horizontal tag bracket I put one washer on the bolt first before bracket then used the other two on the diff side.
    (Gone) 2014 M109R B.O.S.S.
    (Current) 2019 M109R B.O.S.S.
    Cyclops LED headlight, Hard Krome Sideburner exhaust, Side Mount Tag, Under-tail turn signals
    May 2019
    N/A
    Quote Originally Posted by tcolt45 View Post
    Thanks for the reply, that's exactly what I was thinking to do.
    Did U use regular plate bolts on the plate? Holes on the bracket seem a little big. I have the little reflector ones on my tail tidy now, I know those would def work, but wanted to do spikes or bullets, just don't wanna buy something that's gonna be too small.
    Jul 2008
    Forney, TX
    Quote Originally Posted by Bunkz View Post
    It should of came with the big bold that mounts to the rear diff. I have my washers setup the same as well
    I believe mine came with the bolt anyways. But I have had mine for 10 years
    May 2019
    N/A
    Came with the big bolt n washers for the diff. No bolts for the plate tho. Probably just gonna risk it n order whatever I like the look of. If they're too small, some washers should do the trick.
    Jan 2015
    Frederick, MD
    I am using spikes I got off of amazon. they work perfectly.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jul 2008
    Forney, TX
    Ok yes I just ordered some spikes off amazon for the plate. I miss understood what you meant.
    Here is the set I have
    Look at this on eBay
    https://www.ebay.com/itm/302079981946
    May 2019
    N/A
    Perfect! Haha I was looking at these earlier. Thanks again
    May 2019
    N/A
    No worries, thanks for the info
