Motor issues
Results 1 to 7 of 7
Thread: Motor issues
    Very Active Member Keepup's Avatar
    Jul 2014
    Raliegh
    Default Motor issues
    I'll try to explain as best a possible getting 2nd hand info. When the bike is cold it starts up perfect but once it warms up good the motor starts making noises and oil is not pumping or moving around or not reaching all the parts like it should. The bike will as shut off. Do i need to replace the whole engine?
    Very Active Member hunt1moore's Avatar
    Feb 2008
    Monroe, NC
    Quote Originally Posted by Keepup View Post
    I'm not a resident expert but just curious what you mean by "the bike will as shut off"?
    Also, how do you know oil is not pumping or reaching all the parts?
    Jun 2013
    GA
    Check for codes.
    https://www.m109riders.com/forums/sh...d.php?t=348234
    It could be the oil pressure switch or the actual pump.
    Check the magnets on your drain plugs for metal shavings. Also check the speedo sensor for metal shavings. If you find them then the oil pump may be degraded and causing low oil pressure. To be through simply remove the oil pan and check the bottom and the screens for metal.
    I had several issues with mine that I should have done something about well before now. Like speedo would bounce at first and sometimes it would say I'm doing 140 when cruising at 45. After seeing my oil pump I'm sure I didn't have much longer before problems got much worse. The good news is my crank and Conrad bearings and journals were immaculate despite the abuse my '06 has been subjected to.
    My vote is rebuild if you find these things. Change the shift forks as they are most surely worn the the cause of most of the shavings if you find them. And solid shift rods are a must.
    '19 M9 '06 M9
    '09 commander
    Jun 2017
    Florida
    I may have you confused with someone else (I talk with a lot of people) but didn't you have some engine work done not long ago?
    BCS
    Jul 2014
    Raliegh
    Found out it was metal shaving stuck in the oil valve port.
    Feb 2009
    Oklahoma City
    Wow! WTF?? That doesn't sound too good. I'm glad it's never happened to my 14 year old Nine.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Jun 2013
    GA
    Sucks to hear this but you will likely have to replace your oil pump. Since the metal got that far both pump gear sets will likely be damaged. Unfortunately the case has to be split to get the oil pump out. When the oil pump is out remove the outer gear set and then remove the single Phillips head screw to inspect the second (high pressure) gear set. Both will likely be scared especially the inner pump housing.
    Things to watch out for. The oil pump drive gear (above the oil pump gear) has an extremely small pin that keys it to the balance shaft just behind the clutch basket. It is NOT a press fit and will fall out very easily and end up in the oil pan. The oil pump gear(driven) attached to the oil pump shaft has a much larger pin that passes completely through the shaft. It is a slip fit and will fall out as well plus there is a washer just behind the pin. The last two are both pump gear sets (inner and outer) have the same style floating pins that will fall out as well.
    '19 M9 '06 M9
    '09 commander
