Need urgent help with FI alarm
Results 1 to 10 of 10
Thread: Need urgent help with FI alarm
    Nov 2017
    Dubai
    Default Need urgent help with FI alarm
    Hello guys
    I have replaced my stock exhaust two years back on my 2013 M109R with Cobra speedster swept and i debaffled it to
    couple of days back the FI alarm went on, i took it to the dealer and he told me that the code is C46: Exhaust control valve actuator (EXCVA) and to replace it should cost me 350usd ++, but the technician explained to me that this sensor is just there to work with the stock exhaust and i can just install any aftermarket eliminator to disable the FI alarm
    is it by any mean alarming? and should i replace the sensor or just buy healtech ES eliminator or any other one to get rid of the alarm as advised by couple of guys
    Aug 2018
    go to ebay and search M109R servo buddy. It is simple plug and play and tricks the ecu to think that it has the servo on there. When you did your exhaust, there was a metal cam that went on your servo and was attached to the exhaust bracket. That tricks the ecu as well, and also is know to go bad. Once you put your servo buddy on, you can undo the servo itself and just remove the big black box from the bike for good.
    https://www.ebay.com/itm/Servo-Buddy...ss!20874!US!-1
    Formerly known as BigpapaM109
    Jun 2017
    Edmonton, AB
    Quote Originally Posted by bigpapaXCT View Post
    Or if you were planning on having your ECU flashed, have BCS do it and he will disable it directly on the ECU.
    Jun 2017
    Florida
    Quote Originally Posted by Sledge View Post
    Sorry, not shipping overseas any longer.
    Only doing North America for the foreseeable future. (USA & Canada)
    BCS
    Jun 2018
    Concord, VA
    Did you just do the exhaust or have you done the intakes too?
    Nov 2017
    Dubai
    Quote Originally Posted by UVATom View Post
    Only the exhaust, no intakes so far
    Jun 2017
    Edmonton, AB
    BCS
    Oops, I should have looked closer, I didn't realize he was in Dubai.
    Very Active Member tcolt45's Avatar
    Jan 2015
    Frederick, MD
    yeah just look up Servo Buddy.. That is all i did to prevent the FI light with an aftermarket exhaust.
    (Gone) 2014 M109R B.O.S.S.
    (Current) 2019 M109R B.O.S.S.
    Cyclops LED headlight, Hard Krome Sideburner exhaust, Side Mount Tag, Under-tail turn signals
    Member DoubleA's Avatar
    Sep 2012
    Hillsboro, Oregon
    i installed aftermarket exhaust and started to get an FI light due to the set valve. i used this thread to disable this and have had no issues. done this 7-8 years ago on my 2007 M109R
    https://docs.google.com/file/d/0B4h4...it?hl=en&pli=1
    You can find this in the frequently asked questions on this site.
    Nov 2017
    Dubai
    Thanks a lot guys, i have ordered the servo buddy so will install it and let you know the updates
