Cobra Swept with K&N Air filter only
Results 1 to 7 of 7
Thread: Cobra Swept with K&N Air filter only
    Nov 2017
    Dubai
    Default Cobra Swept with K&N Air filter only
    Hello
    I know this question has been raised many times, but still i can't find one solid answer for it
    currently i have a cobra swept on my 2013 M109R and XTRE, can install K&N filter only or i need to have a fuel management?
    and if yes i can does it improve the performance or it is pointless?
    the dealer here in UAE told me yes you can and it will improve the performance however some forums/articles are saying no
    any advice will be appreciated
    Apr 2018
    Maryland
    I would do fuel management personally. Either a PC or similar or get your ECU mapped. My suggestion would be to hit up BCS and have him map your ecu. I know you said your from the UAE, so shipping might be a hassle, but outside of that it’s the way to go.
    Apr 2018
    Maryland
    I read that the first time that you already had the filter too, now I see that’s not the case. Add the filter and fuel management.
    Active Member Frotosride's Avatar
    Jun 2013
    GA
    If your bikes come from the factory with o2 sensors you may get away with doing both but the maps will only support what the factory set as limits. With that being said, you will definitely not get all the performance gains possible and you will surely get a lot of popping on deceleration. The fuel cut upon throttle lift will be more noticeable and heard better by the exhaust popping louder than what you likely already have with just pipes.
    Absolutely do some kind of fuel management even if it's just a piggy back and not a reflash of the ECU.
    '19 M9 '06 M9
    '09 commander
    Dec 2007
    Toronto, Ontario, Canada
    Once you start on the 'mods' road you need to continue going forward. The rule of thumb is that if you replace both air filters and pipes, you should get some form of fuel management. In reality fuel management will gain results without pipe and filter replacement, especially with a smoother running engine with added performance.
    Jun 2017
    Florida
    Quote Originally Posted by asillito View Post
    Adding more fuel though a catalytic converter (stock exhaust) will result in a much hotter exhaust due the cat working overtime and eventually to the failure of the cat converter.
    Using something with static maps to mildly tune specific areas or the entire fuel map set may be just fine, but using something like a Cobra Power Pro that pours on fuel during acceleration is not the best idea with a stock exhaust that has a cat converter.
    BCS
    Quote Originally Posted by ayman.shaalan View Post
    Hello
    I bought a 2018 brand new left over the beginning of last year and first thing I did was cobra swept and power commander, runs like a dream
