Fuse box cover
Results 1 to 10 of 10
Thread: Fuse box cover
    Jan 2020
    Vancouver,BC
    Default Fuse box cover
    Last one for the night-promise ! I noticed that the bike I purchased on Tuesday was missing the fuse box cover ( the one under the seat) and the fuses were all
    crooked and bent in the box-obviously being unprotected from the weight of the rider. Couldn't believe the PO did nothing about that. Makes me a bit worries about what else he has neglected to do on the bike- oh well risk you take with CL purchase.
    Is there anywhere I can purchase this fuse cover box from ? or any other quick fixes anyone can recommend ?
    cheers
    Very Active Member tcolt45's Avatar
    Jan 2015
    Frederick, MD
    you can check at this site below. they have lots of diagrams of stock parts.
    http://www.oneidasuzuki.com/store/cy...acement-parts/
    (Gone) 2014 M109R B.O.S.S.
    (Current) 2019 M109R B.O.S.S.
    Cyclops LED headlight, Sideburner exhaust, Side Mount Tag, Under-tail turn signals, Low & Mean Chin Spoiler, Arnott Air Ride
    Very Active Member Frotosride's Avatar
    Jun 2013
    GA
    http://www.oneidasuzuki.com/store/pa...r-2006-08.html
    Pc #2 should be what you're looking for!
    "Beat it like a red-headed Ford":
    '19 M9 '06 M9
    '09 commander
    '87 silverado on35's'87 c10 lwb(LS twin turbo sleeper project)'83 k20'83 k5 cucv 6.2 Detroit
    Jan 2020
    Vancouver,BC
    Quote Originally Posted by Frotosride View Post
    Awesome thanks guys !
    Jan 2020
    Vancouver,BC
    Quote Originally Posted by Saffer View Post
    Want USD 60 to ship to a $2 part to Canada-man ! I think this is a cover for a starter relay-not same as fuse box cover I assume ?
    Very Active Member Chrispy's Avatar
    Jan 2018
    Delhi, Ontario
    Sounds like you’d be better off going to the dealership for those parts with that price
    Jun 2013
    GA
    If it's the main(pics below) then that's an assembly . You will have to unpin each wire and re-pin them in a new assembly. Not hard but that's probably why the PO didn't do it. I'd have to look at the diagram to see if that part is available.
ID:	386582   Click image for larger version.
ID:	386584   Click image for larger version.
    '19 M9 '06 M9
    '09 commander
    Jan 2020
    Vancouver,BC
    Hi -yes it's the fuse block that lies next to the battery. Location not clear from your pics.
    Jun 2013
    GA
    My battery holder isn't installed but that's the right one in my pics. If you attemp this it will be easier to remove the battery, starter relay mounts and the whole battery holder/tray. This will give you the most slack in the harness to in-pin the fuse box and re-pin the new one.
    '19 M9 '06 M9
    '09 commander
    Jun 2013
    GA
    I do not see that piece in any diagrams. You may have to get a cheap harness from eBay to replace it. Good part is you get practice un-pinning the eBay one befor doing the actual bike.
    '19 M9 '06 M9
    '09 commander
