Front wheel
Thread: Front wheel
    Member Kwoteman11's Avatar
    Harrisburg Pa
    Does any one know what the largest size front wheel m109r can handle without changing the rake?
    I haven't heard that the brake is the problem? It is generally the fender and forks.
    160 is max with stock fender and rim.
    170 requires 17" rim.
    180 is max WITHOUT fender, with stock tubes, not sure which rim.
    That's all I've heard, fwiw.
    Good luck with your search.
    edit: haha, I just re-read your question in conjunction with the other replies... lol I'm an idiot.
    Very Active Member Mrtallguy67's Avatar
    Aug 2013
    Gardner, KS
    Quote Originally Posted by Kwoteman11 View Post
    Does any one know what the largest size front wheel m109r can handle without changing the brake?
    Im assuming you are refering to the wheel and not the tire in your question. You can run a 21'' front on stock trees. Anything larger you will need to change the tripple trees to a raked version.
    BOTM: SEPT 2016
    'Veni, Vidi, Velcro' - I came, I saw, I stuck around.
    Very Active Member Weedahoe's Avatar
    Aug 2014
    Albany GA
    21s can go stock rake
    23s should go 6 degree although some ppl chance it
    26s must go 9 degree
    I have a 26 and ride a lot of miles, most on out of town trips and brakes are never an issue.
    Very Active Member IKNOWP's Avatar
    May 2011
    HOUSTON
    26” is the max I’ve seen. Seen couple of bikes with a single rotor on them. I choose to keep the dauls it’s a lot wheel for a single brake. Have no brake issues.
    Chrome frame,Chrome belly pan,Chrome DLP swingarm, 10" wheel w/300 Avon,Chrome one piece fork tubes,Chrome front and rear brake calipers,Chrome Galfer wave brake rotors,Chrome Sumo-x 9 deg trees, 26" front wheel, Front and Rear air ride, Corbin heated seats, HID projection headlamp conversion, Six channel Led system.
    Yeah, 21'' is the max you can do without changing anything.
    What to love about Klarus G20 Flashlight? The Klarus G20 https://totalguide.org/best-tactical...us/g20-review/ is one of the brightest flashlights of 3000 lumens, has 4 different lighting modes, 2 switches, 150 hours maximum run-time, waterproof and lots of advanced features. Isn't this product pretty cool and amazing?
    Quote Originally Posted by Natable View Post
    Natable, welcome to the Forum Bro. In keeping with common/proper Forum protocol, you should consider creating a thread introducing yourself to the Forum. Do you own a 9? If so, what year, mods, etc? Please provide pics if you have them.
    Bobby
