Negative Battery Cable
Results 1 to 3 of 3
Thread: Negative Battery Cable
    Aug 2019
    FL- GA line
    Default Negative Battery Cable
    Just found my negative battery cable disconnected from the frame anyone have a pic where it bolts to the frame on 2007 M109r?
    Very Active Member Hogan109r's Avatar
    Dec 2013
    Myrtle beach sc and cornelius nc
    Quote Originally Posted by Aaron32 View Post
    Originally Posted by Slowmo12
    Thank for the input... Unfortunately I can't do that right now I just had surgery on my foot so I'm stuck on crutches doing what I can on crutches while trying not to put any weight on it. Do you know of a way using a socket to turn the motor over. I heard some people say check the negative wire and make sure it's tight but I can't find where it ends
    The frame ground wire is on the right side of the bike behind the side cover.
    You can see where it connects in the photo below. (#24)
    If you remove your derby cover on your generator case you will see a plug behind this.
    Remove this plug and you can insert a socket through this hole and turn the crank by hand. (See photo below)
    BCS
    Aug 2019
    FL- GA line
    Quote Originally Posted by Hogan109r View Post
    BCS
    Thanks so much.
