Front springs
Results 1 to 6 of 6
Thread: Front springs
    Jun 2018
    Concord, VA
    Looks like a seal has started leaking after 95,000 miles so was looking for some suggestions. Found these but didn't know if there were better options. Was looking at the 1.1 kg/mm for $110.
    https://www.partsgiant.com/p348768-r...h-fork-springs
    Not looking to lower it any and I am around 250lbs for just normal riding. Was hoping to find a complete kit with seals but doesn't look like one is sold that I can find.
    Jun 2017
    Florida
    Quote Originally Posted by UVATom View Post
    I installed 1.1 kg springs in my forks a couple of years ago and it was a huge improvement.
    I am around 230 # and could bottom out the stock springs without trying too hard.
    The 1.1 kg springs will be much stiffer, you just have to cut new longer pieces of 1" PVC pipe to get the pre-load correct.
    You can see in the photo below how much travel I now have on the forks.....and there is no way you will ever bottom them out now.
    These are the springs I bought, but Racetech is fine also.
    https://www.meancycles.com/store/par...?partID=226110
Name:	Big Bird 3.jpg
    Jul 2008
    Forney, TX
    I also picked up the 1.1 race tech springs last week. Gonna install over the winter
    Very Active Member MR.X's Avatar
    Mar 2010
    L'Islet, Qc, Canada
    Racetech 1.1 was the way to go for me I'm at 260!
    Very Active Member Chilly Rock's Avatar
    Sep 2009
    N.Houston, Texas
    I had a leaking fork seal about 2 yrs ago and upgraded to Racetech 1.0 springs in the process. As others have stated, huge improvement over stock springs. I followed Andy Medina (Some9) video and got it done. https://www.youtube.com/watch?v=14sSacYg1yA
    Very Active Member hunt1moore's Avatar
    Feb 2008
    Monroe, NC
    Sonics are in both my bikes and work great plus they are less $.
    You will need a tool to change out the spring. Traxxion. You will also need to cut the provided spacer to the correct length.
    Just some information that may help.
