Generator Cover Cap Oil Drip
Results 1 to 10 of 10
Thread: Generator Cover Cap Oil Drip
    Default Generator Cover Cap Oil Drip
    Have a slight oil drip from my generator cover cap,should there be oil behind this cap?
    Active Member
    Mar 2015
    England
    No there should be no oil
    Active Member Sneikz's Avatar
    Jun 2018
    Kirrawee, NSW, Australia
    Sure it hasn't dripped from the air intake due to excess oil?
    Sent while not riding
    Live long and ride hard \\ //
    Jul 2008
    Forney, TX
    Where is the generator cover located?
    Jun 2017
    Florida
    Pretty sure the OP is talking about the derby cover.....which sits on the outboard side of the generator cover.
    @ OP there should be no oil behind the derby cover.
    Remove the screws at 2, 6 and 10 oclock and the derby cover will come right off and you can look behind it.
    BCS
Name:	Gen Cover.jpg
    Jul 2008
    Forney, TX
    BCS
    If he has oil there its only coming from 2 places. Left air filter or the front valve cover gasket
    Removed derby cover and it's dry,removed air filter and puddle of oil in bottom,must have migrated down and started drip from cover.Thanks for the advice and why they have screws in the cover that have no purpose except for looks is odd
    Jul 2008
    Forney, TX
    Quote Originally Posted by CORMORANT View Post
    Lol yep they are only at 10, 2, and 6 oclock
    Just like to mention as an ex Harley guy I was going to call it a Derby cover but didn't want to offend anyone so found the actual name Suzuki calls it Generator Cover Cap (:
    Nov 2009
    ARLINGTON, TX
    You likely wouldn't have offended anyone here, because we all refer to that component as a “Derby Cover.” Although there a many bike manufacturers out there, most of the components are referred to using the exact same terminology/nomenclature.😊👍🏽👍🏼👍🏻😊
