First Service
Results 1 to 22 of 22
Thread: First Service
    Member TexasM109r's Avatar
    Aug 2019
    Texas
    Default First Service
    I have a 2019. Just passed 700 miles. I need to get the first service done but dealers are quoting $400-$700 to do it. I was thinking maybe $150-$200. I don’t understand why it’s so much. Is it worth finding someone to do the first service or should I just do an oil and differential change and be done? Thanks for any help or tips.
    Download the manual here and do it yourself. Besides the rear diff and oil change they are suppose to do some Tq checks. It shows in the manual what to check.
    Sent from my SM-G975U using Tapatalk
    Very Active Member Montanalg's Avatar
    Sep 2006
    Mouse House
    I agree......only time my 07 has been to the "stealer" was for a recall. Do it yourself or find a trustworthy independent shop to do your work. Of course most places will charge $80+ an hour for labor. That's why its best to do it yourself. Plus you will know the bike better and enjoy knowing that "you" did the work.
    Enjoy The Ride
    Very Active Member meierjn's Avatar
    Apr 2015
    The Rose; Central Alberta
    I bit the bullet and took mine in for the first service. I had the shop make sure that they completed everything that was listed in the manual that was supposed to be done for the first service, and ensure that it was listed on the invoice. In the event of a warranty issue I didn't want any questions on whether or not the service was done. I don't remember it costing that much though. I think I paid around $400-$450. I plan on doing the majority of the other scheduled maintenance myself.
    Aug 2019
    Texas
    Thanks for the input guys. I’m not that mechanically inclined. I can do the oil and diff change but really anything else and I’m kind of lost. I’ve searched for the first service list but can’t seem to find what I’m looking for. Do y’all have a link or something that gives me the run down on what all needs to be done? Thanks for all the help.
    Quote Originally Posted by TexasM109r View Post
    Do you have the manual?
    Sent from my SM-T580 using Tapatalk
    Starts on page 2-2 in the manual.
    Pg 2-29 is the page that has all the chassis torques. And after that page list the pictures where all the bolts are at to check.
    Very Active Member majalomalk's Avatar
    Feb 2017
    Birmingham england
    I think the first service cost so much becouse they are suppossed to check the valve clearances I haven't seen one that needed adjusting after 20.000 miles let alone on the first service
    Aug 2019
    Texas
    I have the owners manual that came with it. I’ll look when I get home. I skimmed through it when I bought the bike. Never had a first service quoted this high before. Thank you all for your help. It’s nice to have a group like this.
    Thats the owners manual. You need the maintenance/shop manual. I believe there is link here or over on FB. I'll see if I can find it
    Here is a link to the shop manual
    Link is still good, I just downloaded another copy myself.
    https://www.manualslib.com/download/...r-Vzr1800.html
    Very Active Member DutchM1800R2's Avatar
    May 2014
    Netherlands
    Any concerns about warranty if you don’t do this first service at a dealer?
    Apr 2015
    Houston, TX
    I have a 2014 with 6k mikes. The only maintenance I’ve ever done on it, oil, air filter and battery.
    Aug 2019
    Texas
    Thanks Dreamer
    Maryland
    Default To do it yourself or not; that is the question. Here's the answer.
    I agree with everyone that the cost you were quoted seems high. I was quoted $250 for my first oil change and that did not include the synthetic oil. So, what did I do? I got a copy of the “service” manual, not “user” manual. Purchased a motorcycle lift (get a good one) and did it myself for the cost of the lift and supplies. The next oil change then only cost me for the oil itself.
    You say you’re not mechanically inclined, you might want to find a cheaper dealer. Why? Because you’ll note on YouTube, m109r oil changes are a bit tricky. Go to YouTube.com and type “m109r oil change procedure”. You will see a dozen or more excellent instructional videos for how to do it yourself.
    You must run the engine for 10 minutes, get the bike level to even check the oil level. After you drain the old oil you must add the “EXACT-EXACT-EXACT-EXACT” amount of oil to the micro-ounce to the crankcase. If you add too much you will have a mess on your hands. No winging it, no eyeballing it; you’ve got to be exact and the bike has to be level, not leaning on the kickstand. If you don’t want to buy a jack, put a brick or 2x4 under the kickstand and be very careful not to over-level the bike the other way, or it will tip over to the right.
    Lastly, when you put the drain plug back in, remember the pipes may still be hot if you ran the engine prior to beginning. You ask, “why would I run the engine?” Because the hot oil will flow out faster, easier and completely.
    Now here is why you might want to use a dealer. Usually they will check the clutch travel on the cable. This is important because a new clutch cable will stretch a bit and mess with your friction engage point. You’ll know because it will become progressively harder to go from neutral to 1st gear and a knee jerking experience to go from 1st to 2nd without practically lifting your foot off the left peg. Believe you me, no fun.
    What else, the dealer will usually check your radiator fluid and top-off your rear differential and ensure your tire pressure is optimal. Still, I think $750 is waaaaaayyyyy to much, but a trip to the dealer because of a clutch cable that won’t allow you to change gears is even worse especially if you tear up one of your clutch plate trying to slip a gear. My advice to you, if you’re not confident, call around to a few rice-rocket dealers that are accustomed to Japanese bikes. Ask for a quote for oil, cable inspection, etc. You may find the whole bundle for a mere 150~250.
    Hope this helps.
    Mike Way m109r lover forever!
    Where are you located?
    Aug 2019
    Texas
    Quote Originally Posted by Mike Way View Post
    Hope this helps.
    Good write up. Thanks for the insight. I’m still shopping around. I think I found a spot that will do the first service for $300.
    Aug 2019
    Texas
    Out towards Ft.Worth, Tx.
    Holy cow you guys pay a lot down there! Mine was like $250 CAD (which is like... what... $37 USD?).
    That was the only visit except for tires - I have since done all my own fluid service.
    If you have questions or need a hand let me know. Im out by Terrell.
    Aug 2019
    Texas
    Thanks. I appreciate the help. Haven't done anything yet.
