Rear brake
Results 1 to 11 of 11
Thread: Rear brake
    Nov 2014
    Guernsey
    Default Rear brake
    My rear brake seems to be almost non existent. I’ve put new pads in, changed the fluid and bled fully, cleaned the pistons and ensured all working ok but I still have to boot the pedal hard to get any effect at all. Any suggestions or is it just the weight of the bike?
    Very Active Member majalomalk's Avatar
    Feb 2017
    Birmingham england
    Make sure everything is lined up correctly at the master cylinder if not the push rod can bind and give a crap pedal.
    Dec 2007
    Toronto, Ontario, Canada
    Use a non-permanent marker and mark rear disc, then while riding, hammer the rear brake. If the mark is still visible, you know there isn't much pressure of the brake pad on the disc. Consider this a start to your diagnosis
    Nov 2015
    Lift the rear of the bike off the ground and apply the rear brake as you turn the rear wheel. A slight amount of pressure on the pedal should lock the rear wheel.
    Jun 2018
    Concord, VA
    Question on your brake caliper. Do you have the bracket that relocates it under the swing arm? If so then it is impossible to bleed if the caliper is mounted on the bike since the bleeders point down.
    Nov 2014
    Guernsey
    Caliper is in the standard place. I've tried bleeding again and no air coming out at all, I tried both bleed nipples. The pedal is now almost locked solid and won't return properly so guessing the cylinder is seized? Any more thoughts?
    Jun 2018
    Concord, VA
    It does sound like you will have to take everything off and clean the system but I would start at the pedal and look for something wrong and work your way up. Check and make sure you didn't overfill the reservoir.
    Active Member
    Mar 2015
    England
    As to the pedal not returning, I had this last year and it was the pedal pivot rusted up. Suzuki put little or no grease on it, check gear shift pivot at the same time as that's the same.
    Default The rotor itself?
    It's possible the rotor itself is worn to thin and not within spec. You will need a micrometer to check it. Best of luck
    Feb 2009
    Oklahoma City
    Quote Originally Posted by R2Doucebag View Post
    Ohhh, I doubt that very seriously. I've been riding since 1975, never had that problem. Especially with a damn rear brake. Most are useless as a tick on a hound dog. The M109R is no exception. Locks up way too easily. I rarely, if ever, even bother using the stupid thing. As badly as I overuse the fronts on all my bikes since way back when, never worn out a rotor by making it too thin. I'd pay to see that. LMAO!!
    Not from riding use. But obviously, someone turning a rotor down could over do it. I've never had a rotor turned down. Change pads and keep-on-keepin-on.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Jun 2018
    Concord, VA
    Actually all of my rotors were out of spec due to wear. What that means as far as performance, I am not sure. My rear was about .020" too thin before I changed it. Both fronts are about .010" thinner than the book minimum but I am waiting for the pads to wear out before replacing them.
