Aftermarket exhaust
Results 1 to 7 of 7
Thread: Aftermarket exhaust
    Default Aftermarket exhaust
    Hi All,
    I've decided to grab an aftermarket set of pipes. Forgive my ignorance but what else will be required? I've also grabbed the 02 sensor plugs but do I need a servo eliminator? TIA
    Jun 2017
    Florida
    If you have a North American M109R then you will not need O2 eliminators.
    You will either need to get a ESE (Exhaust Servo Eliminator) or have your ECU flashed to override the Exhaust Servo Fault parameter.
    If you have a European or Australian M109R that does have O2 sensors the ECU flash can override the O2 sensor fault parameter.
    What exhaust did you purchase?
    BCS
    Active Member
    Aug 2018
    BCS
    Oh jeez, you coulda saved me $79. I didn't Know your ECU flash would remove the C046 and bought a servo eliminator.
    Jun 2017
    Florida
    Quote Originally Posted by Baldi View Post
    That option just became available last week when new software updates were implemented.
    Before that it was not available for the M109R with the software we use.
    BCS
    Apr 2006
    Traveling America
    I also thought the servo eliminator solved the issue. Back in the beginning the rule was no fuel mod was needed when changeing either the exhaust or the intakes. But if you did both, you would need to get a fuel management system. But that was before 2010. Not to say that changing that mapping even after changing one modification would help.
    Coming to a city near you..
    Bang for the Buck Mods link
    CLICK HERE
    Active Member
    Aug 2018
    BCS
    No worries. My Servo Eliminator has been delivered to NY. Waiting for mid November to get it here.
    BTW, please do send out my ECU so it is delivered in NY by 10 November, thanks :)
    I've purchased these from meancycles. I'm in Aus and it's a 07. I've purchased the 02 sensor bypass and exhaust plugs and was thinking that would do the trick. Happy to hear more feedback. Thanks guys 👍🏽
Name:	Screenshot_20190520-132040_Samsung Internet_1572341173661.jpg
