Killswitch as a turning-off method
Results 1 to 22 of 22
Thread: Killswitch as a turning-off method
    Aug 2019
    Brazil
    Default Killswitch as a turning-off method
    Hello, folks. I usually turn off my bike by using the killswitch, but I was recently told that it's a practice that I should avoid because of damage on the electronics. Can anyone tell me if that's true or just some superstition?
    Nov 2009
    ARLINGTON, TX
    I think someone may have been trying to influence you with their own personal belief/idea.
    Here’s what I’ve been taught, both formally and informally...
    On a motorcycle, a KILL switch has several purposes. The motorcycle KILL (or STOP) switch is in series with the ignition switch. When the KILL switch is open, the motorcycle will not start. Most motorcycletraining courses suggest that you get in the habit of using the motorcycle KILL switch to shut off your bike. Of course, subsequently you must remember to also turn off your ignition switch immediately afterward.
    Jan 2018
    Delhi, Ontario
    Oddly enough when I took my motorcycle training course they recommended using the key to off the engine.... however I generally use the kill switch anyways lol
    Nov 2009
    ARLINGTON, TX
    Quote Originally Posted by Chrispy View Post
    I guess there seems to be different opinions, based on norms/beliefs in certain areas around the world. I’ve had my 07’ M109R since February 2009. I’ve been turning it off using the kill switch now for almost 11 years, and I’ve never had an issue with the kill switch malfunctioning. I honestly don’t believe it matters either way, since most ignitions in newer bikes are linked to the kill switch.
    Feb 2009
    Oklahoma City
    I totally ignore the kill switch. Never used one in the over 40 years I've been riding. Except for those exceptionally rare occasions where, for whatever reason, the bike refuses to turn over. And you find out your big thumb inadvertently hit the damn thing. LMAO!!
    Been riding since 76. Never heard the ruomr that using the kill switch is bad for the bike. That's a good one. Mwahahaha!!!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Active Member
    May 2013
    Bratislava, Slovakia
    I generally use the kickstand to turn the bike off, then remove the key. I haven't touched my kill switch in years. I'm still here alive and well and my bike runs as good as new. I wish I had your problems guys
    Active Member
    Mar 2015
    England
    Personally I use the key, the only use for the kill switch is when you're along side your mate at lights and you lean over and flick his off as the lights change, great fun.
    Feb 2009
    Oklahoma City
    Quote Originally Posted by breadfan View Post
    I do this if I'm parking the bike pointing downhill. Where the possibility the bike might roll off the side stand. It happens. So, I leave the bike in first and put the stand down. Then roll the bike forward until the drive line slack is taken up. Bike can't roll now. Same if parking pointing uphill and it's somewhat steep. Otherwise, I just leave it in neutral and shut it off with the key.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Active Member Mxboost's Avatar
    Jun 2019
    Bossier City LA
    I use the key to shut the engine off. Only time I use the kill switch is when I'm on an incline, and am going to park it in gear.
    Sep 2013
    Cary, NC
    Post
    I use the key to power down the engine. I've accidentally hit the kill switch twice, once while cruising and once while parked. Powering down the bike with the key is a one step process. I don't have to worry about if I left the bike on or the key in the ignition switch.
    Apr 2017
    Ontario, Canada
    It's a logical AND circuit - the bike will not work unless the Kill Switch AND the Ignition (AND the Side Stand when in gear - same relay circuit as the kill switch) are engaged. Killing one before or after the other makes no electrical difference to the bike whatsoever.
    It could however, cause you to forget your key.
    Or leave your lights on.
    Or tip over while the bike is running as you try to reach for the key first.
    Or continue rolling at speed with no oil pressure.
    Or any number of other ridiculous things.
    But to your question - electrically, as far as the engine is concerned - it makes no difference.
    And I personally use it exclusively.
    Aug 2019
    Brazil
    Thanks for all the replies. A fellow M109r owner has given me that advise, which I have found rather strange, so I came here to clarify.
    Active Member Luap's Avatar
    Jun 2019
    Central NY
    Quote Originally Posted by The Prospector View Post
    haha you to, eh?
    2019 M109R B.O.S.S. red/black
    MODS: LED signals, Integrated tail light, Luap hole-saw mod, axle mounted plate, no beaver, carbon fiber look tank bra, dual air horn, black spiked grips, "bar end key" mod, drink holder :), more to come
    Nov 2015
    I began riding before there were kill switches, so I never became accustom to using them. When I taught motorcycle rider education in the 80s and 90s, the curriculum specified using the kill switch to turn off the engine. I taught the course according to the curriculum, but I didn't do as I taught, because I don't think it's necessary.
    However, I use the kill switch when parking on an incline, so the bike is in gear when the engine stops. I do the same when transporting my bikes in the trailer. When the front tire is nestled in the chock, I stop the engine with the kill switch to insure that it is in gear and locked into position while I am attaching the straps.
  17. #15
    FACTS! It's called a kill switch for a reason.
  18. #16
    Apr 2015
    The Rose; Central Alberta
    I've always used the kill switch to turn off the bike then turn off the key. It's just the way I've always done it. Probably a result of growing up riding off-road and dirt bikes that never had a key and only had a kill switch.
  19. #17
    MoCo Maryland
    Interesting post. I always shut the bike off using the kill switch. Reason being, I always leave my bike in gear when I park. That being said, my clutch hand is holding the lever in so there is no free hand to turn it off by key. Have done that since I started riding, close to damn near 50 years. (started riding at a young age) Never been an issue
  20. #18
    Sep 2013
    Cary, NC
    Post
    When parking on an incline, I use my kickstand to power down and leave the bike in gear.
  21. #19
    Feb 2009
    Oklahoma City
    You only have one arm? You're holding the clutch with your left hand, what's your right hand doing? I turn off my key with my right hand, even if I'm holding the clutch with my left. Anyhow, generally when I shut mine off with the bike in gear, due to being on an incline, I just simply put the side stand down. Voila, bike shuts off. Sometimes I use the kill switch, but not often. Mostly I ignore it.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  22. #20
    Jul 2008
    Forney, TX
    I use the kickstand with the bike still in gear to shut down. I have used the kill switch before, just not my normal process. The guy that says you shouldnt use the kill switch to turn the bike off because it can mess up the electronics.....Whats really the diff? You are using the kickstand switch to turn the engine off.
  23. #21
    Nov 2009
    ARLINGTON, TX
    Well, it’s apparent that the conclusion to this topic is that many of us have different preferences and practices with regard to shutting off our bikes, and there’s no right or wrong method. My final thought is...whatever practice works for someone makes it the perfect method for them...and neither method is better or worse than the other.
  24. #22
    MoCo Maryland
    LOL I'm not as flexible as I once was. So that works for me.
