Rear Master changing
Results 1 to 2 of 2
Thread: Rear Master changing
    Active Member Hawkie's Avatar
    Aug 2013
    Adelaide Australia
    Default Rear Master changing
    rear brake just bottoms out, has fluid and no leaks so suspect master seals.
    it looks a night mare to remove the master, what has to come off to make the job easy?
    Very Active Member TheFNG's Avatar
    Sep 2014
    Cape Cod MA
    maybe a stupid question, but have you inspected the rear pads for wear and tried to bleed the rear caliper first, before getting into removing the master? Note that our brake system in linked to the front aslo. If you crack the lines at the Rear Master Cylinder you may need to bleed the front brakes as well.
    09' C109RT Thunder Teardrop Intakes;Cobra PowrPro;GIpro TRE/gear indicator;cobra exhaust;Tsukayu 7" Stereo/GPS Boox One Fairing;Tsukayu Jumbo Strong bags;fender chrome; Rear Master cylinder Chrome;Tank bib;headlight visor,driving light visors,speedo visor and directional visors;Throttle lock; Kuryakyn cup holder;Kuryakyn mirrors;Kuryakyn Dually ISO Highway pegs;TMS Trunk; zXe head light and driving light bulbs;Draggers;Denali air horn
