Cam chain
Results 1 to 15 of 15
Thread: Cam chain
    Default Cam chain
    Hi there has anyone had a problem with their cam chain coming off
    In the rear cylinder
    The bike is a 2011 model
    A few weeks ago the bike decided to make a big noise in the engine
    And since then the bike is in the garage being strip down
    Aug 2017
    uk
    not snapped ? bottom chain still ok ?
    Aug 2017
    uk
    going by that pic ^ it looks like the exh cam outer sprocket has spun on its hub ? they are only a press-fit. bent valves will be the cause of your loss of compression eh
    Very Active Member Hogan109r's Avatar
    Dec 2013
    Myrtle beach sc and cornelius nc
    Quote Originally Posted by dar1800 View Post
ID:	385644Click image for larger version.
    Hi just got the latest pictures
    Not looking goog
    More pic
    Another one
    More info
    Aug 2017
    uk
    looking like oil starvation eh, that rear exh cam is probably the last gallery in the oil supply (and probably the hottest area of the whole engine)
    Mar 2013
    Calgary, AB
    Yup I was just thinking the same thing from the burn marks. It either got too hot or had not enough oil or both. How many Km/Miles are on the 9?
    Feb 2009
    Oklahoma City
    What's not enough oil? As I've posted before, a friend had been having shifting trouble. I told him bring it over, let me change the oil. It had been over five years since the last one. When I drained the oil, got 1.25 quarts on the drain. 1.25 out of a four quart motor. Just Wow! Still runs to this day.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Active Member
    Mar 2015
    England
    Its a 2011 bike not sure how many miles but less than 20k regularly serviced running semi synthetic oil.
    Guessing cam seized initially then gear was spun off cam during diagnosis of problem when engine was restarted.
    Rear exhaust cam is at the end of the pressure oil feed galleries for sure but those grooves in the cam surface?
    My bike has 23500 miles on the clock
    And is service every year
    I use silkolene 10 40 semi
    Feb 2009
    Oklahoma City
    My 2006 is less than a hundred miles away from 36,000. If it wasn't going to be a wet weekend, I'd pass that mark this weekend. But alas, Mother Nature has other plans.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  17. #15
    Jun 2012
    Detroit
    Check to see if the piston hit the valves and damaged them. Pretty common when a cam chain goes.
