USB PORTS
Results 1 to 6 of 6
Thread: USB PORTS
    Very Active Member fatboy99's Avatar
    Jul 2012
    Smashville, TN
    Default USB PORTS
    What do you recommend that's sweet & simple to mount & hookup?
    Very Active Member mist82's Avatar
    Oct 2017
    US
    Hopefully u can see. Back plate of headlight housing. Easy to position, hidden, clean, and close to handlebars to use a short cable to the phone.
    Also these are very easy to wire. Yeah, and reads your current bat voltage. So there is that :-)
    Sent from my PCT-L29 using Tapatalk
    Active Member Luap's Avatar
    Jun 2019
    Central NY
    Quote Originally Posted by mist82 View Post
    A link or source would be useful :)
    2019 M109R B.O.S.S. red/black
    MODS: LED signals, Integrated tail light, Luap hole-saw mod, axle mounted plate, no beaver, carbon fiber look tank bra, dual air horn, black spiked grips, "bar end key" mod, drink holder :), more to come
    Oct 2017
    US
    Quote Originally Posted by Luap View Post
    https://www.amazon.com/dp/B07GTZ89NH..._ajSEDb3ZFAWCA
    That's what I purchased. Can't really give you any step by step as I haven't documented it, but you open up the headlight housing, drill at the desired spot a hole big enough for this to go through, pull through, and then tighten with the nut that comes on it. I have a wire coming straight from the red bat terminal into the housing for some other purpose, used that, and wired second wire to ground. Mine came with a fuse inline on red wire so it's ready to go.
    Took about 15 min
    Very Active Member shrk352's Avatar
    Apr 2014
    Michigan
    https://www.amazon.com/Battery-Tende...gateway&sr=8-1
    I have a female cigarette lighter plug zip tied up under my tach. This allows me to upgrade or change out chargers as technology changes. Having a fast charger in there is pretty nice as most modern phones are power hungry, and when I'm riding on longer trips I usually have GPS and bluetooth going so I want my phone to stay topped up.
    Jan 2018
    Delhi, Ontario
    This is what I did
