Feels like clutch is slipping
Results 1 to 6 of 6
Thread: Feels like clutch is slipping
    Active Member bad1o9's Avatar
    Jun 2008
    NV
    Default Feels like clutch is slipping
    Has anyone had this issue, when I get on throttle feels like rear tire is spinning out but it's not, thought my clutches were going bad just replaced them & all washers & push pin, old disc looks good. Bike shift's nice now but will still slip when getting on it ?
    Jun 2018
    Concord, VA
    If you changed the discs then you probably also checked and readjusted the cable?
    Very Active Member Weedahoe's Avatar
    Aug 2014
    Albany GA
    To properly adjust the clutch is to adjust it in three different places.
    Details are in the service manual but you make changes at the clutch basket on the exhaust side of the engine, then at the cable on the opposite side and lastly at the lever.
    Aug 2019
    WNY
    I was having the same issue until i left a little more slack in the clutch cable after doing the adjustment. turned out I was going a touch too tight and when at High R's, it felt like it was slipping. More than likely its in your adjustment.
    Jun 2008
    NV
    Quote Originally Posted by crshoveride1 View Post
    thanks I started doing a little fine adjustments seems to be working
    Jun 2018
    Concord, VA
    How old is your bike? It has some chrome so you might want to check your motor mounts.
